Old 07-25-2013, 08:37 AM   #1
mellie815
mellie815 is on a distinguished road
mellie815's Avatar
Default 2004 Vue Intermittent Turn Signal problem
Hello everyone!
I have been reading through previous threads to learn about this issue. It just started for me about a month or so ago and has only happened a handful of times to date.
I start driving normally and the turn signals work fine but later, for no apparent reason, I turn the 'lever' to activate the signals but nothing visibly happens inside the car. I say this because each time it has happened, I haven't been in a location/situation where I could easily pull over to see if the signal is working at the lights/bulbs.
Each time the signals fail to work, I HAVE tried the 4-ways (Hazard) lights and they have worked each time, at least, inside the car. I push the button and the indicator lights on the dash illuminate. Again, I haven't yet been able to get the signals to fail when I am parked so that I can check the outside lights, but when the turn signals 'fail', I refer to the fact that there are no lights on the dash, nor the 'tick, tick', sound you get when they are blinking. The lights and tick tick sound DO work for the hazards.
Since I have the absolute worst luck finding mechanics that are competent, I am wondering if this is something I could fix myself (although I am not a 'car' person. I am willing to try, though!)
Any advice you could provide would be very appreciated.
Thanks!
Add to mellie815's Reputation
Rate the quality of this post and help mellie815 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mellie815 is offline   Reply With Quote
Old 07-25-2013, 11:54 AM   #2
Chazberry
Chazberry's Avatar
1995 SW2
Default Re: 2004 Vue Intermittent Turn Signal problem
Have you seen this thread? Looks like a lot of good info . . .
http://www.saturnfans.com/forums/sho...d.php?t=155994
Add to Chazberry's Reputation
Intermittent turn signal function. Flasher relay issue? cityhawk S-Series Tech 7 05-13-2013 07:25 PM
Intermittent turn signal prob - Grounding issue? 92SC2 S-Series Tech 8 12-30-2010 01:48 AM
DRL- turn signal intermittent Mrianti Ion Tech 0 09-22-2009 10:40 PM
Intermittent turn signal problem Robor007 Astra General 1 03-27-2009 10:19 AM
intermittent turn signal problem corvus S-Series General 5 09-02-2003 10:35 PM
