Old 01-25-2012, 02:02 PM   #1
Sweetcheeks4565
Sweetcheeks4565 is on a distinguished road
Default No Heat in my SC2
I have a 1996 Saturn SC2, I can let the damn thing run for 30-45 mins and NO heat comes out. The AC works just fine and when I'm driving the car the heat still doesnt work.
All of the fluids are full and its not leaking anything. Under the hood all the hoses are new. I'm thinking the problem could be my heater core but I dont have any leaks outside or inside the car. My other ideas is the thermostat...
Any way to chance to tell if its the thermostat BEFORE I tear apart everything?
Add to Sweetcheeks4565's Reputation
Rate the quality of this post and help Sweetcheeks4565 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sweetcheeks4565 is offline   Reply With Quote
Old 01-25-2012, 02:45 PM   #2
Default Re: No Heat in my SC2
Typically, a failed thermostat means your car will take a long time to get up to 1/4 on the temp gauge, and only hit 3/8 if you are sitting still for a really long time. Temp will normally top out at around 160~170F if you have a way to measure actual temps (scanner, or thermometer in the return stream, in the reservoir).
If your temp gauge gets up to 3/8 or higher fairly quickly, I'd suspect the heater core or air mix flaps.
Old 01-25-2012, 03:03 PM   #3
Sweetcheeks4565
The Thermostat Gauge in the car doesnt leave the 1/4 mark on the cold side.
Old 01-25-2012, 03:22 PM   #4
RobertGary1
Replace thermostat. Use the Stant one, not the cheapy from Autozone. Napa stocks them.
no heat/lack of heat problem mr18436572 S-Series Tech 7 04-16-2015 11:01 PM
'04 Vue heat problems (no feet heat) PatrickMcD Vue Tech 5 01-24-2014 05:49 PM
no heat in my 97 sc2 nice186 S-Series Tech 10 06-20-2009 09:48 AM
low heat 97 sl2 larold1126 S-Series Tech 9 12-10-2006 05:09 PM
Heat DHOOP S-Series Tech 3 11-06-2004 12:54 PM
