Old 02-17-2011, 05:43 PM   #1
ςατμяη gμψ
ςατμяη gμψ is on a distinguished road
ςατμяη gμψ's Avatar
Wrench Fuel Gauge Problem
I have a 2002 Saturn SC2 and a week ago, the fuel gauge started having problems. It is erratic and doesn't show the correct reading. It went down to E after just a few days. When I filled up at the gas station, it only needed half a tank to fill completely and my gas mileage was normal (around 30 MPG). Do you think this is a sensor and if so, where would it be located and how expensive is it to replace. One more thing... the light on the fuel gauge itself seems dim. The other gauges seem normally lit. Are these related? Thanks!
AEM Short Ram Intake
Disabled DRLs
Cleaned Throttle Body
New Front Brakes and Rotors
New Spark Plugs and Wires
New Battery
Charged A/C
New Michelin Primacy MXV4 Tires
Add to ςατμяη gμψ's Reputation
Rate the quality of this post and help ςατμяη gμψ reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ςατμяη gμψ is offline   Reply With Quote
Old 02-17-2011, 05:59 PM   #2
BV22
2002 SC1
Default Re: Fuel Gauge Problem
What did the gauge read after you filled it up???
Add to BV22's Reputation
Old 02-17-2011, 06:02 PM   #3
Wolfman has a How-To on fixing the gauge for '91-'99's, might work for '00-'02 as well (unless the How-To states otherwise, don't remember).
Old 02-17-2011, 09:12 PM   #4
ςατμяη gμψ
ςατμяη gμψ's Avatar
The fuel gauge went up to full. I haven't driven much since, so it is still showing near full. I might have to drive a few days to see if problem repeats.
Disabled DRLs
New Battery
Charged A/C
Old 02-20-2011, 01:03 AM   #5
ςατμяη gμψ
ςατμяη gμψ's Avatar
OK, I've driven about a hundred miles now and the fuel gauge has gone down to 1/2 tank. So I guess I still have a problem with a sensor or something.
Disabled DRLs
New Battery
Charged A/C
Old 02-20-2011, 01:21 AM   #6
100 miles for the first 1/2 of the tank is about correct. As long as it is consistent and you figure out when to fill it up you are OK, as it is not a precision measuring instrument.
Old 02-20-2011, 02:18 AM   #7
ςατμяη gμψ
ςατμяη gμψ's Avatar
For the couple years I have owned my car, I usually get near 200 miles before the needle dips below 1/2 tank. Something has been wrong with the gauge for the past 2-3 weeks. It went down to E a week ago and only required 6 gallons or so to fill up completely at the pump.
Disabled DRLs
New Battery
Charged A/C
Old 02-20-2011, 02:52 AM   #8
AlexofNazareth
AlexofNazareth will become famous soon enough
AlexofNazareth's Avatar
2002 SL1
2006 VUE Red Line
yeah 100 is not a half a tank, haha. it should at least be 200.
'02 SL1 [w/ a snail-shaped muffler]
'06 Vue RL
Saturn Night is Special ED.
Add to AlexofNazareth's Reputation
Rate the quality of this post and help AlexofNazareth reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AlexofNazareth is offline   Reply With Quote
Old 02-20-2011, 11:23 AM   #9
Each one is different. The tank holds 12.1 gallons and I run 32mpg with the pattern of use for the car. At 1/2 I put in about 6 1/2 gallons and absolutely full is real close to 13 gallons. You are now trying to fix something that very well not be broke.
Old 02-20-2011, 11:31 AM   #10
2NDSOUT
2NDSOUT's Avatar
1999 SL
I've seen this happen in my 94 SL2 that I bought a few years back.
As a matter of fact; I've seen it happen a few times and as recent as yesterday.
I had put a few gallons of gas in my car on late Friday and then topped the tank off on Saturday afternoon. While driving on the highway; my completely full tank gauge went from Full all the way down to a half tank, then down to a 1/4 tank and fluctuated...then *very* slowly gradually went back up to a half tank and then back up to the Full Mark.
I've learned to live with it as I only bought the car for $700. As long as the car runs, that is the only thing I am concerned about.
It is amusing to watch from time to time, but obviously this could be a sensor or float issue, wouldn't it?
Wolfman's Fix:
http://www.saturnfans.com/forums/sho...ght=fuel+gauge
Now that I found wolfman's fix and read through it...it's not a float or sensor issue at all, but more of a resistance issue. Read the thread for more details.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 02-20-2011, 12:18 PM   #11
That is probably the level sender resistance element. If the float fails it is all over.
Old 02-21-2011, 05:11 PM   #12
BV22
2002 SC1
If the gauge goes all the way to full when the tank is full, you can rule out bad connections or wiring. Agree with OldNuc that your problem is likely the sending unit, which usually involves dropping the fuel tank to replace. If the gauge is consistent, even if it is wrong, I would learn to live with it.
Old 02-21-2011, 05:17 PM   #13
TXSaturn02
TXSaturn02's Avatar
Yepper - some things aren't worth getting repaired. Glad I've learned to let some things go...
New owner report of 08/08/19: 234,408 Miles
As of 07/25/18: 51,495 Miles
Old 02-21-2011, 10:18 PM   #14
Add fuel every time it drops to 1/4 for a while and that wil help fix it so it is more accurate.
Old 02-22-2011, 01:43 AM   #15
ςατμяη gμψ
ςατμяη gμψ's Avatar
Dizzy Re: Fuel Gauge Problem
I'll try the tips mentioned, but if it doesn't fix it I have a feeling it will bother me and I will break down and get it fixed, unless it's crazy expensive. Right now, I'm keeping the trip odometer on so I know when I get over 300 miles to fill up the tank.
Disabled DRLs
New Battery
Charged A/C
Old 02-22-2011, 02:26 AM   #16
A couple of points. Running the tank almost dry is hard on the fuel pump. It will last much longer if the tank is mostly 1/2 full or above. You have the digital cluster and there is no official way to replace just the fuel gauge. You replace the entire cluster. the reason it drops so fast is the magnet on the empty side is considerably stronger than the one on the full side. By maintaining the tank close to full will eventually increase the strength of this full side magnet and the decent to E will take longer and become more representative of the actual level. It is also prudent to operate on the top half of the tank instead of the bottom.
Old 03-28-2011, 02:56 AM   #17
ςατμяη gμψ
ςατμяη gμψ's Avatar
I don't understand it, but it seems my fuel gauge is working properly now and I didn't do anything to fix it. The last two times I filled my tank up, the gauge is working normally. It isn't dropping fast after only a few trips. It's only going near E and lighting the orange fuel pump light when it should. Any thoughts as to why it is working correctly again?
Disabled DRLs
New Battery
Charged A/C
Old 03-28-2011, 03:15 AM   #18
It can be the instrument panel connections if you messed with it at any time, the ground connection for the fuel sender if it exists or the fuel sending unit in the gas tank. About all you can do now is leave well enough alone until it acts up then use process of elimination with the easiest things to check/do first; instrument panel check, ground wiring check, and lastly, removing the tank to pull the pump/sending unit out to check. Hopefully nothing is needed or you find the solution before having to drop the tank.
Fuel Gauge Problem: Update meadows6 Outlook General 29 08-28-2015 05:52 PM
Fuel gauge problem brubro S-Series Tech 2 08-06-2015 02:22 AM
Fuel gauge problem brubro S-Series Tech 8 12-03-2008 09:46 PM
Fuel Gauge problem? NCL200 L-Series General 3 02-11-2005 02:37 AM
fuel gauge problem JimK L-Series General 8 09-23-2003 11:33 PM
