Go Back   SaturnFans.com Forums > Models > Saturn Sky > Sky General
Old 03-15-2010, 10:06 AM   #1
marx404
marx404 will become famous soon enough
marx404's Avatar
2008 Astra XE
Default My top down method
I have read some posts where some may have had trouble with figuring out the easiest way to drop the top on their SKY. The top can be cumbersome sometimes and I learned this method to make putting it down almost effortless and safe for both you and the car. Hope this helps anyone out there. (going off memory so bear with me)
1st, think clockwise. Windows down. From the driver's seat, push the trunk button in the glove box or key fob. Then flip the center roof lever and gently lift the top's edge from the windshield to loosen the pins. Now walk clockwise around the car to the passenger side rear quarter panel and lift the trunk lid. Grab the top from the front part of the frame (by the windshield) and begin to fold it back, guiding the center part of the frame as it goes down. once the top is located entirely over the trunk, firmly but Slowly press the center of the frame down, then the corners until the top is evenly submerged in the trunk. Then with your hand in the center of the trunk lid, push it down firmly closed. If the top is down properly, the trunk should close completely on the 1st try.
When I have demonstrated using this method, it does make putting the top down very easy. Moving clockwise takes you from the driver's seat, safely out of traffic and back to the driver's seat - full circle.
marx404
Saturn lives on.
2007 ION.3
2008 Astra XE
2004 L300.1
marx404 is offline   Reply With Quote
Old 03-15-2010, 02:18 PM   #2
Rick Tinley Par
Rick Tinley Par is on a distinguished road
Rick Tinley Par's Avatar
Default Re: My top down method
Reading yours -- We are nearly identical (going from memory too) but yes clockwise - making one revolution around the car works for me too. Four years and no problems
Rick Tinley Par is offline   Reply With Quote
Old 06-17-2010, 01:46 PM   #3
Shadow_tek001
Shadow_tek001 is a glorious beacon of lightShadow_tek001 is a glorious beacon of lightShadow_tek001 is a glorious beacon of lightShadow_tek001 is a glorious beacon of lightShadow_tek001 is a glorious beacon of light
Shadow_tek001's Avatar
this seems like several steps excessive to me.
Don't do it on a busy street - do it in a parking lot or somthing.
1-in car, loosen latch.
2-press trunk release
3-get out
4-open trunk
5-dump roof in trunk
6-close trunk
7-get back in car
Shadow_tek001 is offline   Reply With Quote
Old 10-26-2010, 02:54 AM   #4
BackBlade
BackBlade is on a distinguished road
I'll add, don't try this operation while the car is moving. I've seen some owners who attempt to drop the top while parked momentarily at a stop light, and it's seldom a smooth flow.
BackBlade is offline   Reply With Quote
Old 10-26-2010, 03:39 AM   #5
boboman
boboman is on a distinguished road
2000 SL2
Now that would be a funny sight to see at a stop light :P that could quite possibly make my day right there. :P
boboman is offline   Reply With Quote
Old 10-27-2010, 10:19 AM   #6
gpartrid
gpartrid is a jewel in the roughgpartrid is a jewel in the roughgpartrid is a jewel in the roughgpartrid is a jewel in the rough
gpartrid's Avatar
2008 AURA XR
2008 SKY Red Line
It's also recommended that the windows be lowered before lowering or raising the top. I believe this is also stated in the owner's manual.
2008 AURA XR
Ocean Mist
Sunroof
Loaded!
Built: 07/19/07
2008 SKY RL
Silver Pearl
Black on Black
6 Disc w. Monsoon
Chrome Wheels
4 Pedals
GMPP Turbo Upgrade & CAI
Built: 09/20/07
gpartrid is offline   Reply With Quote
Old 10-27-2010, 11:28 AM   #7
ToledoEngineer
ToledoEngineer is on a distinguished road
ToledoEngineer's Avatar
2008 SKY Red Line
1992 SL1
Technically, it's impossible to do this while the car is moving. The clam will NOT open unless you disable some safety mechanisms. It was designed to prevent this. It's in your manual.
I've done it. Both putting the top up, and then another instance putting the top down, while at a red light. Down is usually easier. Hardest part is not getting out of car. But it IS doable...and smoothly at that if you plan it out.
"Education is the progressive realization of our own ignorance"
1992 SL1: 149k miles
2008 Sky RL: 35k miles
ToledoEngineer is offline   Reply With Quote
Method for finding independent Saturn svc? emilio700 General Saturn Discussion 0 10-28-2009 01:17 PM
My Method of Cooling my Car Off w/out Running the AC CrunkedRL Vue Red Line 6 05-23-2009 11:53 AM
Tire rotation method. froggy81500 Ion General 6 09-12-2006 11:38 AM
New Advertising Method For Sky FLEUTZ Sky General 2 02-21-2006 07:24 PM
Can someone explain the the MMO method to clean your valves? auxmike Miscellaneous Tech 6 02-13-2003 09:53 AM
