Old 04-23-2009, 06:42 PM   #1
bdobraj
bdobraj is on a distinguished road
1993 SC2
Default cleaning egr valve
for cleaning the egr valve i heard before you clean it and put it back together, that while its off the car, you can run the car and get some of the crap out. is that recommended? and should you spray some carb cleaner down in there and run it aswell? thanks.
Add to bdobraj's Reputation
Rate the quality of this post and help bdobraj reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bdobraj is offline   Reply With Quote
Old 04-23-2009, 07:07 PM   #2
Default Re: cleaning egr valve
Carb cleaner not needed. With EGR installed warm up the motor and then remove EGR. Restart engine with hood open. Car will promptly rev to 4000 RPM and will blow all the carbon out of the exhaust track. Shut off car and reinstall EGR.
Old 04-23-2009, 08:52 PM   #3
saturncrzy
saturncrzy will become famous soon enough
1992 SL2
For the egr valve itself i would like to add it is a good idea to clean the pintle on the egr valve and the other port thats in it. Get yourself an old tooth brush, but makes sure it dont have a flexable end. use card cleaner and get as much build up out as you can and reinstall.
Add to saturncrzy's Reputation
Rate the quality of this post and help saturncrzy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturncrzy is offline   Reply With Quote
Old 04-24-2009, 12:12 AM   #4
You can soak the bottom of the EGR valve in a pan full of carb cleaner. needs to be deep enough to just cover the bottom flange. 1/4 to 3/8 inch. As long as the black round solenoid is not in the cleaner it will work. Scrape the carbon off off the pintle seat. Hold it open and scrape it clean with a small screw driver. probably will have to make a scraper to clean the seat area in the body also if the pintle seat has carbon on it.
Old 04-24-2009, 09:49 AM   #5
OnDaGround
OnDaGround's Avatar
1993 SC2
Self cleaning is awesome.
Saturnless...
Old 06-21-2010, 11:53 PM   #6
lxvgto
lxvgto is on a distinguished road
Hello all, and thanks once again for excellent technical information at Saturnfans.
I would like to caution you on the use of carb cleaner and other solvents on the EGR valve. I had a code P0404, so I removed the EGR to clean it, using some carb cleaner in the process. Unfortunately, although I did not use much cleaner, i inverted the EGR and actuated the pintle with some carb cleaner inside the base.
After re-installing the EGR, the car had all the signs of a faulty EGR and a test with the homemade can gasket (thanks richpin!) confirmed that the EGR is faulty. So in trying to clear a SES, I cost myself $100 for a new EGR!
The last time i did this a brass-bristled wire brush did the trick with no solvent!
Add to lxvgto's Reputation
Rate the quality of this post and help lxvgto reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lxvgto is offline   Reply With Quote
Old 06-22-2010, 12:47 AM   #7
The only way a solvent can destroy an electric EGR valve is if the isolation diaphragm has failed. You have to keep the exhaust gas out of the electrics also. The valve section is totally separate from the electrical section.
The IAC is an entirely different issue though, keep solvents out of the works or its toast.
Old 06-23-2010, 07:07 PM   #8
Telyx
Telyx is on a distinguished road
2002 SL
I've used brake parts cleaner on my EGR valve a few times now with no ill effect.
Add to Telyx's Reputation
Rate the quality of this post and help Telyx reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Telyx is offline   Reply With Quote
Old 07-29-2010, 08:16 PM   #9
JerryHughes
JerryHughes's Avatar
1997 SL
Was wondering why, after cleaning the throttle body and PCV valve and still having the car stumble upon acceleration----I cleaned the EGR valve and the car now runs like a top. I was even considering changing the spark plugs but that isn't needed. Lots of carbon inside the valve.
Old 07-31-2010, 08:47 AM   #10
Pitcher
Pitcher's Avatar
Question Re: cleaning egr valve
About how long should the engine run with the EGR off?
Thanks!
Owned 4 other S-Series.
Add to Pitcher's Reputation
Rate the quality of this post and help Pitcher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 07-31-2010, 09:58 AM   #11
bigbfarm
bigbfarm is on a distinguished road
1997 SW2
I don't let the motor run for long with the EGR off. Engine will rev up to the 4K rev limiter. Maybe 3-5 seconds. I would think anything that is going to get blown out would do it then.
Add to bigbfarm's Reputation
Rate the quality of this post and help bigbfarm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigbfarm is offline   Reply With Quote
Old 04-07-2013, 10:41 PM   #12
silverblackjoe
silverblackjoe is on a distinguished road
I remove EGR, cleaned pintle and ports with appropriate cleaner, brush and "pick", on intake side scraped ports and vacuumed out with shop vac. replaced gasket. runnin real nice.....312,000 miles.....inherited for plumbing job, can't say enough to thank the people here on this post. You guys Rock!
Add to silverblackjoe's Reputation
Rate the quality of this post and help silverblackjoe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
silverblackjoe is offline   Reply With Quote
Old 11-01-2019, 06:09 PM   #13
dmfgoo
dmfgoo is on a distinguished road
A steam cleaner is a device for removing dirt from surfaces using hot steam. What is the principle of operation of this device, the differences between different models and the possibility of its application? And the most important question is whether it is worth buying a steam cleaner https://cleanhomeguide.com/best-carpet-steam-cleaner/ at all or is it better to get along with a vacuum cleaner and a mop?
Add to dmfgoo's Reputation
Rate the quality of this post and help dmfgoo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dmfgoo is offline   Reply With Quote
Old 11-09-2019, 02:01 AM   #14
focusofheart
focusofheart is a jewel in the roughfocusofheart is a jewel in the roughfocusofheart is a jewel in the rough
...and a steam cleaner, a vacuum cleaner or mop has what to do with cleaning an egr valve?
Saturn 1998 - SL2
Singer 1952 - 301A
Add to focusofheart's Reputation
Rate the quality of this post and help focusofheart reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-09-2019, 09:06 AM   #15
Waiex191
Waiex191's Avatar
It is a spambot. Please report it using the little exclamation point button in the lower left corner of its post. I wish Charlie would give some of the faithful moderation privileges so we could zap them.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
EGR valve cleaning abinder S-Series Tech 9 10-22-2008 05:57 PM
EGR Valve Cleaning clickclickw00t S-Series Tech 1 05-30-2007 03:14 PM
EGR Valve Cleaning - HELP! LaraKimbo S-Series Tech 5 05-12-2007 12:13 PM
EGR Valve cleaning diablo2070 S-Series Tech 5 04-02-2007 09:11 PM
Cleaning EGR valve wolfehunter S-Series General 9 07-18-2006 11:03 PM
