Old 06-05-2007, 10:46 PM   #1
dandres87
dandres87 is on a distinguished road
Default SL2 Subframe
The tire shop said I needed to replace my subframe. I checked it out and it was battered up a nice bit. They told me 2k+ for everything I needed and I just smiled and left. So I'm going to replace it myself. Anyone have some steps and advice?
Add to dandres87's Reputation
Rate the quality of this post and help dandres87 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dandres87 is offline   Reply With Quote
Old 06-05-2007, 11:10 PM   #2
Greg1
Greg1's Avatar
1997 SW2
Default Re: SL2 Subframe
This is a cut and paste from the How To section posted by Woflman.
2k sounds high and unless they are trying to gouge you I'd guess they quoted for other replacement parts like the control arms.
Cradle removal: (abbreviated but easy enough to follow)
Jack up the car and support it with jackstands. You MUST get the car (measured at the frame) AT LEAST 16 inches off the ground.
Remove both front wheels and inner splash shields.
Remove the front (engine) splash shield from under the radiator
Seperate the tierod ends from the knuckle (both sides)
NOTE: This is NOT 100% necessary, BUT it can help to make removing the steering rack to cradle bolts easier, so I recommend you do so.
Seperate the ball joints from the knuckle. LEAVE the knuckles with brake componants, drive axles and struts still attached "hanging"
Support the engine and transaxle from ABOVE using a couple of appropriate length 2X4's layed accross the upper radiator support to the firewall upper portion and some STRONG rope/chain/cable through the lifting eyes. MAKE SURE that the engine/transaxle WILL NOT drop down when the cradle is removed from beneath them. ("Hanger" MUST be TIGHT before proceeding)
Remove the three nuts holding the exhaust down pipe to the manifold and the bracket and/or rubber hangers just forward of the catalytic convertor. Allow the down pipe to sag down (no need to remove it)
Remove the two bolts securing the steering rack to the cradle
Remove the LOWER engine dogbone mount and LOWER transaxle to cradle mount.
Tie the radiator SECURELY to the upper radiator support with some STRONG twine.
Break loose, but DO NOT REMOVE the 4 cradle to space frame bolts. ENSURE THAT NOTHING IS NOW ATTATCHED TO THE CRADLE! (except the lower control arms and sway bar) THEN remove the REAR cradle bolts FIRST. Support the FRONT of the cradle with a floor jack and THEN remove the front cradle attaching bolts.
SLOWLY lower the cradle making SURE that the RADIATOR does NOT come down with it and that NOTHING else is still attached or interfering with it lowering.
Drag the cradle with the sway bar and lower control arms still attached out the FRONT of the car, OVER the still attached exhaust pipe.
Install is reverse (LOL) DO NOT FORGET to use the front cradle alignment holes (mentioned in a post above) to align the cradle BEFORE tightening the bolts.
Hope that helps (and that I did not forget anything)
We are GM. You will be assimilated. Resistance is futile.
97 SW2 5-Sp 273k -mine
Add to Greg1's Reputation
Rate the quality of this post and help Greg1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-06-2007, 01:51 PM   #3
dandres87
thx, takes a couple of days i assume?
Old 06-06-2007, 03:09 PM   #4
amazinghl
Couple of hours if you know what you're doing.
If you don't, shouldn't take more than 6 hours.
00 Insight 72mpg
Add to amazinghl's Reputation
Old 06-12-2007, 05:05 PM   #5
dandres87
so i dropped the subframe np. When i searched pikapart
http://www.pickapart.com/pickyourpartparts.php
for pricing it gives me 2 prices, which one is correct?
Old 06-12-2007, 05:22 PM   #6
Someone else's! I take it you typed "subframe" into the search, right? How can they just puke out a price, without reference to make, model, year, whether they have it, etc.? And a $20 core? WTF would they want with a core subframe? Not to mention that the lower price is ouchy high (I would expect $50-100), and the higher price must be for a gold-plated one.
Try http://www.car-part.com . You can search by distance from your home, brand, model, year (and it knows what other models/years match).
Add to madpogue's Reputation
Old 06-13-2007, 06:40 PM   #7
dandres87
pick a part is the the best bet here in CA for pulling parts, it's not a saturn specific part place or watever. I just go and pull my part and pay for it.
Old 06-13-2007, 07:43 PM   #8
Low Saturn
Low Saturn's Avatar
2000 SC2
The Pick-n-Pulls out here charge $29.99 for it.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Subframe rusted through raymondmm S-Series Tech 24 12-30-2010 02:13 AM
subframe?? shovex S-Series Tech 9 03-07-2009 02:15 PM
dropping subframe MikeNW S-Series Tech 28 07-22-2008 01:59 PM
Help Plzs Subframe On A 95 Saturn sl2 DOHC mike1048184 S-Series Tech 2 10-23-2007 10:00 PM
1998 sl2 cradle replacement(subframe) gman41 S-Series General 5 01-08-2006 01:56 AM
