Old 10-15-2006, 11:32 PM   #1
JaeMarie
JaeMarie is on a distinguished road
Default 2000 SL2 Driver door only opens from inside?
Hey there. What a bad time for this to happen, just as it's getting cold.
I searched but couldn't find anyone else with the same problem.. basically, my driver's door will not open from the outside even if it's unlocked.. I have to reach in either through the window or from the other side and it will open from the inside. just started doing this.
I have off of work tomorrow so before I tear the door apart blindly I was just wondering if this was a common problem, or if anyone else has had this issue?
The car's been a dream other than this little issue, 2000 SL2 5-speed.
Thanks in advance.
Add to JaeMarie's Reputation
Rate the quality of this post and help JaeMarie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JaeMarie is offline   Reply With Quote
Old 10-16-2006, 12:16 PM   #2
justin_zink
justin_zink is on a distinguished road
1995 SL
Default Re: 2000 SL2 Driver door only opens from inside?
Never heard of this happening, sounds like the rod to the handle has either broken, bent, or slipped off.
Add to justin_zink's Reputation
Rate the quality of this post and help justin_zink reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
justin_zink is offline   Reply With Quote
Old 10-16-2006, 01:14 PM   #3
Low Saturn
Low Saturn's Avatar
2000 SC2
Just remove the outter panel and have a look inside. I really dont think the rod going from the handle to the latch would just pop off. Its enough of a chore to get it off when you want it to come off. But anything is possible with these cars.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Old 10-31-2006, 05:32 PM   #4
JaeMarie
Thumbs Up Re: 2000 SL2 Driver door only opens from inside?
Hi guys. Thanks for the tip.
It was BEAUTIFUL out yesterday so I pulled the outer skin and door handle off the door. And this is what I found underneath:
that's not right!
That's why it would open from the inside and not the outside.. because that metal rod is only attached to the outer handle. After popping it back into place it worked like normal:
For good measure, I threw some blue RTV (only adhesive type substance I had on hand) over the two "teeth" of the clip to hopefully keep it from popping off again.
It's been fine so far and I don't look like a tool getting in the car any more!
Hope this helps someone with the same issue; your advice helped me get the door skin off.
Old 10-31-2006, 11:46 PM   #5
Uzzy
Uzzy has a spectacular aura aboutUzzy has a spectacular aura about
Uzzy's Avatar
2002 SC1
Looks good!
I love it when a plan comes together.
Aut viam inveniam aut faciam
If your ECTS is not brass...your ass is grass.
If you have a problem, if no one else can help, and if you can find him, maybe you can hire Uzzy.
Add to Uzzy's Reputation
Rate the quality of this post and help Uzzy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Uzzy is offline   Reply With Quote
2008 saturn astra radio wont shut off after car door opens saturncoupe25 Astra General 11 11-04-2008 08:27 AM
2000 SW2--no domelight when driver door openned. weezerdeadcat S-Series Tech 5 10-26-2008 11:49 AM
Rear driver door latch 97 SL2 mainedvd S-Series Tech 4 12-31-2007 05:17 AM
alarm goes off when door opens. can anyone help? mscott5070 L-Series General 2 06-10-2006 11:25 PM
Canadian Driver review of 2000 SL2 Admiral Beez S-Series General 0 03-08-2005 09:52 PM
