View Poll Results: Should I spend $3,000 on a SOHC motor
Yes 0 0%
No, Buy a new car 5 71.43%
No, Install a new motor and computer 2 28.57%
Voters: 7. You may not vote on this poll
Closed Thread
Old 03-29-2004, 01:55 PM   #1
'01SaturnSL
'01SaturnSL is on a distinguished road
Dizzy Rebuilding my SOHC motor
I want to spend no more than $3,000 on my motor. I need some ideas on what to do. Someone told me to replace my SOHC cylinder head with a DOHC cylinder. But when I called a saturn performance shop, they told me the computer would mess up. Please tell me what I can do to help with my SL. I want to be fast!!! Is the horepower worth the $3,000?
Add to '01SaturnSL's Reputation
Rate the quality of this post and help '01SaturnSL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
'01SaturnSL is offline
Old 03-29-2004, 02:25 PM   #2
TheSaturnKid
TheSaturnKid is on a distinguished road
TheSaturnKid's Avatar
1997 SC2
Default
Dude(chick whatever) a stock spec rebuild is less than a grand easy.
I dont know if you are doing this yourself though???!!!
Easiest way to make more power is just swap a DOHC and pcm of similar year. 00+... But I would find a pre 99 head for it as they flow better and have more header options.
Add to TheSaturnKid's Reputation
Rate the quality of this post and help TheSaturnKid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TheSaturnKid is offline
Old 03-29-2004, 02:35 PM   #3
TheSaturnKid
1997 SC2
Default
OK. If I were in your shoes, I would swap the SOHC out for a DOHC engine and a DOHC (mp3) tranny.
Simplest thing you can do for 24 more ponies.
You have to be sure its OBDII though. So look around for a 96 and newer DOHC engine- Rebuilt or used... Find a 96 and newer MP3 transmission. Find an OBDII PCM for a DOHC.
This is important though- If you get a 96-99 engine you need a 96-99 PCM. If you get an 00 or newer engine you need an 00 or newer PCM. Saturn changed PCMs in 00 from delco to motorola.
There that was easy. And I am willing to wager you will have money left over for bolt ons.
www.6thplannetusedparts.com They can help you more.
Old 03-29-2004, 03:16 PM   #4
Mog
Mog is on a distinguished road
Mog's Avatar
Default
Sell your current one, use that money, and the 3k, and buy a newer one with DOHC. Saturns are cheap.
Add to Mog's Reputation
Rate the quality of this post and help Mog reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mog is offline
Old 03-29-2004, 03:46 PM   #5
Qlara
Qlara is on a distinguished road
Qlara's Avatar
Default
I agree with Mog's suggestion.
Instead of doing such big 'make-over' on the motor, why not just swap the whole car instead? (Sell current + $3K additional) should be able to buy a decent used '01 or even '02 SL2 5-speed.
Add to Qlara's Reputation
Rate the quality of this post and help Qlara reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Qlara is offline
Old 03-29-2004, 04:20 PM   #6
FrozenPilot
FrozenPilot is on a distinguished road
FrozenPilot's Avatar
Default
Wouldn't the DOHC swap require a new instrument cluster as well to take care of the speedo and tach changes?
If you want a faster saturn, the best option is to find a DOHC manual tranny saturn.
Its all about the coffee...
'06 Mazda 6i & '95 Saturn SL1
Add to FrozenPilot's Reputation
Rate the quality of this post and help FrozenPilot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FrozenPilot is offline
Old 03-29-2004, 04:49 PM   #7
TheSaturnKid
1997 SC2
Default
Yes you would need a new cluster among other things.
Hey if he likes the car he has, why not keep it?
Your average Joe CAN swap all these things, you just need a slight mechanical inclination.
BUT... Depending on the status of ownership (its yours not a banks right?) it may just be more feasable to get a DOHC saturn outright. That 3 grand will definately be a nice down payment. And at most dealerships you can buy performance parts there.
Old 03-29-2004, 08:11 PM   #8
wolfman
wolfman's Avatar
Default
I am assuming (you did not list it) that your Saturn is an 01'. That being the case, and if indeed you have $3K to spend, TRADE it with the $3k on something else. (Saturn or not) The used car market is dirt cheap now, your $3k is better spent in that direction than on a rebuild.
Add to wolfman's Reputation
wolfman is offline
Closed Thread
Swapping a 2002 SOHC motor into a 93 SOHC 1995sl1sohc S-Series Tech 11 06-25-2009 09:15 AM
95 sw-1 to 2001 sohc motor swap almoore S-Series General 2 05-20-2009 02:03 PM
Rebuilding 2002 SOHC Motor gizzi S-Series Tech 7 10-09-2008 01:00 AM
Wtb Sohc Motor ur1crazymother Classifieds 10 02-19-2006 09:23 PM
98 SOHC motor in a 95 SOHC car benwah Miscellaneous Tech 1 11-07-2003 10:28 PM
