Old 06-05-2016, 05:03 PM   #1
SaturnTrooper
SaturnTrooper is on a distinguished road
Mad Emergency help!!!! Trans problems
Hey y'all! So I tested my trans solenoids and discovered I needed 2 new ones. I replaced the 2 bad ones and put everything back together to spec. I got it and started the car and there were no leaks and fluid is not low. But when its in park it's in park. Reverse is reverse. Neutral is neutral. Drive 1st and 2nd are also all reverse. Did I mess up the shift linkage somehow? Is there a diagram on what the linkage needs to look like?
Add to SaturnTrooper's Reputation
Rate the quality of this post and help SaturnTrooper reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnTrooper is offline   Reply With Quote
Old 06-05-2016, 07:13 PM   #2
Chazberry
Chazberry's Avatar
1995 SW2
2003 VUE 3.0L
Default Re: Emergency help!!!! Trans problems
Did you actually pull the VB out to replace those Solenoids? Are you just referring to the linkage that connects to the Manual Valve?
https://www.youtube.com/watch?v=cwV4TPL3TDg
Add to Chazberry's Reputation
Old 06-05-2016, 08:35 PM   #3
SaturnTrooper
[QUOTE=Chazberry;2198595]Did you actually pull the VB out to replace those Solenoids? Are you just referring to the linkage that connects to the Manual Valve?
I pulled the VB, opened the VB, took the buss plate off, then Replaced the 2 solenoids and put it all back together
Old 06-05-2016, 08:41 PM   #4
billr
How far did you "open" the VB, far enough that the check-balls may have fell out? How about the linkage that moves the manual spool, has that been checked to see if it is in place, and moves the spool?
Add to billr's Reputation
Old 06-06-2016, 11:11 AM   #5
SaturnTrooper
I'm stupid....I forgot to hook shift linkage back up after it fell down into the tranny. All is well now.....minus the fact I snapped to bolt heads off in the cover and 2 on the valve body!!! Not sure what to do about that other than get a 12 pack and a extractor set and be very careful. Luckily as of now there are surprisingly no leaks so I'll drive as it as is at the moment
Old 06-07-2016, 08:45 PM   #6
Tom Walsh
Tom Walsh is a jewel in the roughTom Walsh is a jewel in the roughTom Walsh is a jewel in the rough
2002 L-Series 2.2L Sedan
I've never had any luck with easy outs. Lefthand thread drill bits do wonders. Often the heat from drilling releases the broken piece and it comes right out on your bit. Harbor freight has them .
Add to Tom Walsh's Reputation
Rate the quality of this post and help Tom Walsh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tom Walsh is offline   Reply With Quote
Old 11-07-2019, 03:02 PM   #7
S-forever
S-forever is on a distinguished road
1991 SL2
Use a torque wrench on any VB bolts! Use 1/4" drive in INCH-lbs. I think the torque is around 96 INCH lbs, aka 8 ft lbs, but a ft lb torque wrench won't be accurate at that low number and might break bolts. I've always been a bit shy about full torque with those small dia, long bolts, so I just ease up slowly to them. Check the manual or someone else for the correct torque - that's the best info I could find.
Add to S-forever's Reputation
Rate the quality of this post and help S-forever reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
S-forever is offline   Reply With Quote
Old 11-07-2019, 03:36 PM   #8
SC2Sick
1997 SC2
1995 SW2
sixthsphere.com owner
2002 Saturn SL2 - RHD
Add to SC2Sick's Reputation
Old 11-07-2019, 04:01 PM   #9
Waiex191
Waiex191's Avatar
That was worth it for the thread necromancer picture.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
trans problems maybe? machflt 2008 Vue 1 10-30-2015 10:20 AM
No Voltage to IACV + Trans problems...Replace Computer or Trans Val Body or Both ialonso S-Series Tech 1 05-22-2009 04:23 PM
99 SL2 Trans. problems malbojah S-Series Tech 0 06-01-2005 07:17 AM
99 SL2 Trans. problems malbojah S-Series General 2 06-01-2005 12:54 AM
trans problems on 04 ion! dncsion Ion General 26 05-27-2004 12:51 PM
