Old 11-01-2019, 12:56 AM   #1
SlowS98
SlowS98 is on a distinguished road
Default S series timing
I have a 97 S series with the DOHC engine. I suspect one of the valves may be burned (or a ring is gone), though I haven't confirmed it yet. I'd like to get it back on the road as cheaply as possible; it's a daily beater, so I don't want to spend more than absolutely necessary.
Is there a way to pull the head without removing the timing cover and re-time the car properly? I know the crank pulley has a timing mark, so could I simply remove the cam gears and then reinstall them when I put the head back on? It seems like as long as I can confirm that the crank is in the 3 o'clock position, I'm golden. Of course, if the timing chain is stretched I'll end up taking off the timing cover, anyway.
Add to SlowS98's Reputation
Rate the quality of this post and help SlowS98 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SlowS98 is offline   Reply With Quote
Old 11-01-2019, 09:57 AM   #2
SC2Sick
1997 SC2
1995 SW2
Default Re: S series timing
Pretty sure you have to pull the cover to reset the tensioner
sixthsphere.com owner
2002 Saturn SL2 - RHD
Add to SC2Sick's Reputation
Rate the quality of this post and help SC2Sick reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SC2Sick is online now   Reply With Quote
Old 11-01-2019, 11:18 AM   #3
Yes, you do have to remove the cover.
Old 11-01-2019, 11:24 AM   #4
With OTC 6685 you can hold the cam gears in place and replace the camshafts without changing the timing. I remember people making custom versions of it for far less than the $200 I see it currently going for.
Even if that tool lets the head clear the gears it'll be super amazing awesome taking off with the timing cover in place; the cover is RTV'd to the block & head and I believe there's a couple of alignment pins that combined with the cover being in place will only let the head come straight up so no chance to get leverage against the RTV.
Old 11-01-2019, 11:35 AM   #5
http://www.saturnfans.com/forums/sho...d.php?t=160333
cant tell if that thread has pics because most are blocked at work
Isn't #3 exhaust the valve that usually burns? Or is it #4? Compression test?
Old 11-02-2019, 07:49 AM   #6
Saturn Night
No. You have to pull the timing cover to remove the cylinder head.
If you suspect a burnt valve or dead cylinder, then you should perform a compression test.
2000 L-series timing chain nightmare. celticwarlock L-Series Tech 15 08-23-2016 06:39 AM
WTB: 91-02 S Series SOHC Timing Cover Macgyver Classifieds 0 07-05-2016 02:49 AM
V6 Timing Belt,2000 L-series s/street L-Series Tech 3 07-04-2007 02:49 AM
S-Series Timing David R S-Series Tech 27 03-08-2004 12:08 AM
Help! 2.2L timing chain snapped @ 67k on '01 L Series thompsbb L-Series General 16 06-16-2003 10:49 PM
