Old 10-11-2010, 09:27 AM   #1
ls3ftw
ls3ftw is on a distinguished road
Default Wrench inside outline of car icon on cluster?
Is this an indication that the vehicle wants "scheduled service" since it differs from check engine or any other "error" light? I did the press brake 5 times like you do to clear the oil change indicator and restarted the engine, this light did not come back on.
What exactly does it mean? The manual says take in for service because it MAY have a problem? hmm
2006 AWD
-2006 Saturn VUE V6 AWD...built by GM, powered by Honda.
-2008 Corvette MN6...poor man's Porsche.
Knowledgable enough to know intelligence comes with humility.
Add to ls3ftw's Reputation
Rate the quality of this post and help ls3ftw reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ls3ftw is offline   Reply With Quote
Old 10-11-2010, 09:36 AM   #2
mrtube
mrtube is on a distinguished road
Default Re: Wrench inside outline of car icon on cluster?
i'm pretty sure you press the accelerator down 5 times, not the brake to clear the oil service light.
I believe a yellow wrench = oil change indicator.
Add to mrtube's Reputation
Rate the quality of this post and help mrtube reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mrtube is offline   Reply With Quote
Old 10-11-2010, 09:59 AM   #3
ls3ftw
The manual identifies this as "service vehicle soon" and appears to be a BCM code? What things could cause this to trip?
I'm talking the wrench in the outline of a car in the upper left of the cluster, not the oil/wrench in the lower right.
Old 10-11-2010, 11:36 AM   #4
ls3ftw
came back on next drive cycle, need to find someone with a techII
Old 10-11-2010, 11:58 AM   #5
ls3ftw
just checked all the bulbs, one of the 5 in the high mount stop is out... would this cause it?
Old 10-11-2010, 12:55 PM   #6
ls3ftw
replaced bulb, no dice, light illuminates when i let off from accelerating... any stores that can read BCM codes?
Old 10-11-2010, 08:54 PM   #7
pdough
pdough will become famous soon enough
pdough's Avatar
2006 VUE 2.2L
Advance and the like cannot read the codes with an off the shelf reader. I had to go to the dealer. If its running OK I'd guess its one of the O2 sensors. How many miles? Is your fuel mileage suffering?
Only way to know for sure is to take it and have the codes read...
Add to pdough's Reputation
Rate the quality of this post and help pdough reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pdough is offline   Reply With Quote
Old 10-11-2010, 09:05 PM   #8
MoparNut
MoparNut will become famous soon enough
MoparNut's Avatar
No, the oxygen sensor codes would set a Service Engine Soon lamp (outline of an engine). This is the Service Wrench lamp, and as stated, is most likely caused by a code in the BCM that will require a Tech2 or equivalent.
And btw, only 3 pumps of the accelerator pedal to reset the oil life monitor
Add to MoparNut's Reputation
Rate the quality of this post and help MoparNut reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MoparNut is offline   Reply With Quote
Old 10-12-2010, 08:07 PM   #9
ls3ftw
Posted in general for more exposure, scanned today with techII... P0873, 4th gear pressure switch on top of tranny, blue/yellow 1 pin wire.
Replacing tommorow, very very common to fail in the honda/acura world and my local saturn dealer stocks them "fail often"
someone should update the FAQ with this one (if there is a FAQ?)
Old 09-27-2019, 07:42 PM   #10
gary48
gary48 is on a distinguished road
When you say to press the accelerator 5 times, is that while it it running?
Add to gary48's Reputation
Rate the quality of this post and help gary48 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gary48 is offline   Reply With Quote
Old 09-28-2019, 12:24 PM   #11
RobertGary1
1996 SC2
No. Ignition on.
Another super common cause for the service light is if the mil lamp is burnt out.
-Robert
Part 2- Getting inside your Instrument Cluster 2NDSOUT S-Series Tech 3 04-19-2011 11:05 AM
97 SL2- Service [wrench icon] Light Starduster_Sat S-Series Tech 14 01-14-2010 06:56 PM
Service Wrench on 2 days after cluster swap srponies S-Series Tech 3 09-19-2007 11:16 AM
Getting inside the gauge cluster edbama2 S-Series Tech 3 04-12-2005 11:09 PM
Service (wrench icon) light TedL Miscellaneous Tech 5 10-05-2003 06:26 PM
