Old 09-03-2019, 08:55 PM   #21
SlayZombi
SlayZombi is a jewel in the roughSlayZombi is a jewel in the roughSlayZombi is a jewel in the roughSlayZombi is a jewel in the rough
2001 SL
Default Re: New Clutch, Possible Issues?
Originally Posted by RobertGary1 View Post
I think he's trying to stall you. I did my clutch and it worked great the moment I got the car back on the ground. But these types of issues are common with bargain clutch kits.
-Robert
Now perhaps I was not explaining how it operated quite right. You have to push the pedal down 100% to get it to go in smoothly (as in normal operation). Even 99% doesn't seem to get it in gear without some manhandling. Engagement is right off the floor. If you say that yours worked great, what exactly does that entail measurement-wise? Allowing a little bit of "slack" in the depressing of the clutch pedal (As in maybe it will still smoothly go into gear when the pedal is 90% down?) or do you mean it engages higher off the floor than what I'm explaining? The clutch kit I got was by a supposedly reputable brand, and in fact here's the exact one I bought from this exact site here:
https://www.rockauto.com/en/catalog/...lutch+kit,1993
It's the Exedy one. And here's the clutch master/slave assembly (Luk). I didn't necessarily cheap out on either, or so I thought.
https://www.rockauto.com/en/catalog/...assembly,10290
Add to SlayZombi's Reputation
Rate the quality of this post and help SlayZombi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SlayZombi is offline   Reply With Quote
Old 09-04-2019, 11:55 AM   #22
"The issue I am having now is that unless I REALLY fully depress the clutch (no I don't mean just bottom out, I mean pretty much past bottoming out), it wont go into gear. I have to struggle to get it in any gear with the car on (off is fine). It doesn't grind or anything, it just wont get into gear."
Remember that from the beginning of this thread? None of those difficulties should be had right after the clutch is replaced. That's what we mean by "OK" or "fine" or "great"; normal operation with no shifting issues or other complaints.
How far off the floor is the pedal when the clutch should start to engage? In the 1-3" range is what I have found over a wide variety of vehicles/years. It will vary, even on the exact same vehicle over time, but if you have to "bend the firewall" to get it to dis-engage, something is wrong. I have run into a couple of those too...
PS: That Exedy kit does not include the flywheel, are you sure that was replaced and was a good quality?
Add to billr's Reputation
Old 09-04-2019, 12:19 PM   #23
OP did you compress the 3 little springs on the clutch cover fingers?
Old 09-04-2019, 09:49 PM   #24
SlayZombi
2001 SL
Yes, I remember that from the beginning of the post, I was mentioning that now, after having driven it for more than a couple miles, I noticed that my initial post may have been slightly exaggerated. This fits reality better from a couple posts ago: You have to push the pedal down 100% to get it to go in smoothly (as in normal operation). Even 99% doesn't seem to get it in gear without some manhandling. Engagement is right off the floor. And yeah I brought all of the parts to him myself. I used a Luk flywheel replacement.
Old 09-04-2019, 09:51 PM   #25
SlayZombi
2001 SL
Couldn't tell you. I didn't do it myself, but looking back at it I kind of wish I did.... Time is hard to come by.
Old 09-04-2019, 09:59 PM   #26
SlayZombi
2001 SL
I suppose that I got a pretty good consensus that what I'm experiencing is not really good or normal. My final question is if I leave this as is and just make sure to always fully depress the clutch before shifting, will any harm be done? Is this particular situation more of a nuisance than a mechanical emergency?
Old 09-05-2019, 10:18 AM   #27
SC2Sick
1997 SC2
1995 SW2
If you aren't fully disengaging you'll fail faster
sixthsphere.com owner
2002 Saturn SL2 - RHD
Add to SC2Sick's Reputation
Rate the quality of this post and help SC2Sick reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SC2Sick is offline   Reply With Quote
Old 09-05-2019, 11:29 AM   #28
RobertGary1
1996 SC2
If you stop at a light and put the car into neutral is it difficult to get back into first? Is it difficult to get into first after reversing? If not the clutch is disengaging enough not to drag. Those are the first signs in this clutch that its dragging.
-Robert
Old 09-05-2019, 11:43 AM   #29
Ifthey were not compressed then it will not disengage properly. Ask the person who did the work as they rarely come out of the box properly preloaded.
Old 09-05-2019, 12:32 PM   #30
I would worry about there being premature failure of the trans syncros, even if they are able to yield smooth shifts right now. My perception is that replacing those syncros is not a trivial or inexpensive task.
Old 09-05-2019, 01:32 PM   #31
There are NO new OEM style replacements. The aftermarket uses brass alloy. If they will sell them out of a kit you are looking at 100+ for a set.
Old 09-06-2019, 12:44 AM   #32
Slowsl1808
Slowsl1808 has a spectacular aura aboutSlowsl1808 has a spectacular aura aboutSlowsl1808 has a spectacular aura about
Op, I would attempt one more talk with your mechanic, all of the symptoms you've mentioned kind of kills off the drivability a bit, not to mention the added stress on the drivetrain components.
I would also be worried about the shift cable & shifter bushings ect.
Add to Slowsl1808's Reputation
Rate the quality of this post and help Slowsl1808 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Slowsl1808 is offline   Reply With Quote
Old 09-06-2019, 12:52 PM   #33
RobertGary1
1996 SC2
Fortunately it doesn't take much time to R&R a clutch in these cars. I finished mine in an afternoon and would probably be faster the second time. Compared to my Focus which took all day and required I take the transmission out of the car.
-Robert
Old 09-08-2019, 02:45 AM   #34
SlayZombi
2001 SL
UPDATE: So I bit the bullet and replaced the master/salve assembly with a new one. No more issues with shifting! Went on a test drive and everything went well except for the 2 times I thought reverse was 5th gear... It's been a long day... Now though, I am getting a popping in the pedal every maybe 1/10 clutch depresses. Any ideas?
Old 09-08-2019, 11:42 AM   #35
I'd lube the clutch pedal pivots.
Add to Waiex191's Reputation
Old 09-08-2019, 06:07 PM   #36
russmet
russmet is on a distinguished road
I went through this on my 2001, Mine was the clutch that had a couple of fingers bent and was not fully releasing. It was bent from the factory. After removing I was able to get to see the issue. I got warranty because after removal I was able to show Oriellys part store some of the bent fingers. the first one was an OEM design part, of course since there is no real OEM anymore so its a copy. I got an after market clutch with a different design and installed it and no issues after . I would say remove the clutch and inspect check the clutch. Like some one said before you can have it off and on in afternoon with help.
Add to russmet's Reputation
Rate the quality of this post and help russmet reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
russmet is offline   Reply With Quote
Old 09-08-2019, 08:42 PM   #37
macbox
macbox will become famous soon enough
macbox's Avatar
1997 SC2
What brand was the master/slave hydraulics your mechanic installed that failed and what brand did you get to replace it?
"The Twins"
#4, "Betty" 1995 SC2m, 163K, 400 Miles per quart. Garage queen. Currently in 1000 pieces for a rebuild.
#7 "Betsy" 1995 SC2, 131K, daily driver.
Add to macbox's Reputation
Rate the quality of this post and help macbox reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
macbox is offline   Reply With Quote
Old 09-08-2019, 09:43 PM   #38
The functionality of any of the prebled systems is a function of their storage and shipping history. Many of them are air bound right out of the box, This alone justifies a wire test immediately after assembly and any perceived clutch anomaly.
Old 09-09-2019, 12:12 AM   #39
SlayZombi
2001 SL
I had a LUK assembly that I then replaced with a Duralast assembly. After taking a look at both of them I noticed a few things different. One, the Duralast master and slave cylinder were made with metal, as opposed to the LUK's fully plastic body. Not saying that it's a giveaway that the LUK was lower quality, but metal holds up far longer over time. Two, the LUK also felt a little sloppy and bendy with the tubing, while the Duralast components were more rigid and substantial. Lastly, the arm that connects the pedal to the master cylinder was noticeably thicker than the LUK's, which looked like a tent pole. Guess I ran out of "LUK" with that brand....
Old 09-09-2019, 12:19 AM   #40
SlayZombi
2001 SL
Yeah and I should have inspected the quality of what I received more thoroughly. I did not know much about clutch hydraulics until now but looking back there were a couple red flags that would have maybe made me think twice about having the new hydraulic assembly put in.
1. There were a few droplets of brake fluid outside of the reservoir when I opened the box. I figured it might have leaked out of the top hole but now I know that that seems unlikely and if it did leak out, that's not normal.
2. The plastic that held the top of the rod on the slave side was already broken (which I did not even know was a thing until I got the Duralast one with the plastic still attached), leading me to believe that the rod had been extended at some point.
3. Shipping packaging was awful, I bet it was a rough ride for the assembly..
02 vue clutch hyd issues.. ShawnL Vue Tech 20 04-30-2017 04:54 PM
97 sl clutch issues? marmitage S-Series Tech 6 11-05-2013 06:23 PM
Clutch issues jamminjames S-Series Tech 1 10-13-2010 07:41 PM
Clutch Issues Firehawk_1989 S-Series Tech 4 04-24-2006 05:16 PM
clutch issues? geekdude S-Series Tech 6 08-30-2005 10:00 AM
