Old 05-04-2019, 03:10 PM   #1
jlbmusic
jlbmusic is on a distinguished road
Default ABS Sensor Bolt
The ABS sensor bolt snapped when I was trying to remove it. Does anyone know the specs for that bolt. I need to replace it.
Add to jlbmusic's Reputation
Rate the quality of this post and help jlbmusic reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jlbmusic is offline   Reply With Quote
Old 05-08-2019, 07:36 PM   #2
TomM96
Default Re: ABS Sensor Bolt
I guess, try a junkyard.
It helps to:
1- use penetrating lube some hours/days beforehand
2- tap the head of the fastener (directly along the shaft, to jostle the bolt down along the threads) with something, like pliers, wrench, hammer.
As vehicles age, stuck fasteners become a big issue, particularly in wet/salty
areas.
Add to TomM96's Reputation
'01 SW2 engine coolant drain plug bolt issues and ISO new bolt hangten247 S-Series Tech 7 06-23-2016 10:28 PM
what are the timing belt tensioner bolt and idler pulley bolt torque values goob Astra Tech 4 10-14-2015 08:05 PM
Crank Position Sensor Bolt/Removal td1238 S-Series Tech 1 02-04-2014 07:32 PM
its a long shot but bolt size for front abs sensor bttwracing S-Series Tech 0 01-20-2010 10:30 PM
Bolt Fairy Strikes! Timing cover middle bolt size? alordofchaos S-Series Tech 8 08-04-2009 11:58 PM
