Old 06-01-2018, 12:04 AM   #1
Commeatus
Commeatus is on a distinguished road
1998 SW2
1997 SW2
Default liftgate support replacement
I'm now the proud owner of a pair of 6x9 boxes that I'm planning on securing to the liftgate in my 98 sw2. My plan is to just hack away the plastic panel and screw directly into the existing speaker screw holes, shouldn't be too hard. I'm thinking this will add an appreciable amount of weight to the liftgate though, and since I just did the hood strut mod, struts are on my mind. Can I replace the liftgate struts with something stronger or will I need to repurpose the hood support rod?
Add to Commeatus's Reputation
Rate the quality of this post and help Commeatus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Commeatus is offline   Reply With Quote
Old 06-01-2018, 10:07 AM   #2
Default Re: liftgate support replacement
McMaster-Carr has tons of strut options, you'll have to measure the open/closed lengths and then get the appropriately rated struts. Oh, they're not "Struts" they're "Gas Springs"
https://www.mcmaster.com/#struts/=1d3ftws
I don't remember how the hatch struts attach to the car, should be the standard eye-bolt but could be something custom just for Saturn too.
Old 06-01-2018, 10:10 AM   #3
toggenburg
toggenburg's Avatar
Is there a better spot to put the speakers on ... like on atop both fender well covers instead? They are sturdy plastic and wiring to them would be tons easier...plus not having to modify the tailgate at all.
Those back struts would last a lot longer without additional weight....it would probably save you life as the hatchback lid would not someday come crashing down on your head or torso.
Old 06-01-2018, 03:09 PM   #4
Commeatus
1998 SW2
1997 SW2
fetchitfido, thanks, I'll do some digging. the attachment seems to be the standard 3/8 ball stud that's common everywhere.
I do a decent amount of hauling and people moving, so I want to retain as much functional space as possible. I'm going to spend some quality time with a JY wagon and see how much space I can create behind the wheel well as an alternative.
Replacement of Mesh Support for Drivers Seat acbrendler L-Series General 4 08-01-2014 09:33 AM
Cracked the plastic on the outside of my liftgate door....need a replacement part Soul Rebel 2008 Vue 2 04-02-2012 01:35 PM
LW300 radiator support replacement mtgarns L-Series Tech 3 12-03-2011 07:16 PM
Rocker Support(?) Removal/Replacement spencer1984 S-Series Tech 2 10-03-2011 09:57 AM
Whining Center Support Bearing - Time for replacement hein Vue Tech 30 02-10-2010 11:26 AM
