Old 05-07-2018, 01:59 PM   #1
anderson95sl2
anderson95sl2 is on a distinguished road
Default Remote key less entry
We have a 1998 sl2. we have had it about 2 years. we do not have the remote
Recently the locks started clicking on there own. I have looked on this site and have seen where others have reprogrammed their remote and solved the problem.
Is there a way to disable the RKE to eliminate this?
I have looked but am unable to find the answer
Thanks in advance
Kevin
Add to anderson95sl2's Reputation
Rate the quality of this post and help anderson95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
anderson95sl2 is offline   Reply With Quote
Old 05-07-2018, 02:09 PM   #2
Default Re: Remote key less entry
It wasn't programming the RKE, it was the door switch. Some have pulled a fuse, apparently, as a temporary stop (no personal experience)
http://www.saturnfans.com/forums/sho...d.php?t=158132
You can buy a remote control (RKE) fob off ebay for $20 or less, and program it yourself
http://www.saturnfans.com/forums/sho...ghlight=remote
For a 1998, one of these numbers will work
16245100-29
218101368
AB01502T
Old 05-07-2018, 09:13 PM   #3
anderson95sl2
I have pulled the relay and I can still here a clicking at the rear wheel well where the RKE is located.
Kevin
Old 05-08-2018, 10:12 AM   #4
Kevin
Wait, I thought it was the locks themselves (in the door) that were clicking. If you pulled the relay, there should be no power.
So, you are hearing a clicking sound in the rear wheel well? Right side?
Try unplugging the RKE right at the module
https://www.youtube.com/watch?v=eLf1cTmL1Wc
Old 05-15-2018, 01:00 PM   #5
anderson95sl2
had to take battery out temporarily for another car. when reinstalled no more issues. if the RKE is unplugged at the wheel well, will that interfere with any thing else?
Thanks in advance
Kevin
Old 05-17-2018, 05:31 AM   #6
sedativechunk
sedativechunk has a spectacular aura aboutsedativechunk has a spectacular aura aboutsedativechunk has a spectacular aura about
sedativechunk's Avatar
Just wanna say +1 on a broken lock/unlock button on one of the doors. I used to use mine constantly on the drivers door and press it damn hard like I was bashing an arcade game button in. Eventually it broke, would get stuck in either position makes the doors constantly lock/unlock.
Anything that you frequently use related to the doors, switches, locks, etc. could cause this issue. As for the FOB; not all Saturns had it. Mine does, and I ordered a switch on ebay many many years ago. Works great to this day, only the trunk doesn't always wanna open.
Add to sedativechunk's Reputation
Rate the quality of this post and help sedativechunk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sedativechunk is offline   Reply With Quote
Old 05-17-2018, 10:17 AM   #7
It may depend - on how it was last programed, and whether you have anything else going on. Take a read here
http://www.saturnfans.com/forums/sho...d.php?t=183598
http://www.saturnfans.com/forums/sho...d.php?t=203618
used fob with new 3 button case for $9.50 shipped
https://www.ebay.com/itm/OEM-GM-Keyl...UAAOSwAata6kRP
$12 for four button case
https://www.ebay.com/itm/New-W-OEM-F....c100005.m1851
Old 05-17-2018, 11:00 AM   #8
floridasl22002
If the clicking/chattering is coming from the door lock/unlock switch on the door panel, then you need to replace those switches. As cheap goes I have not seen anything cheaper designed than those lock switches. Instead of a spring to keep the toggle switch vertical, Saturn use a piece of foam. Sadly, this foam over time disintegrates and when it does it does not keep the toggle switch vertical and away from the contacts. The result of this is that the switch droops, makes contact with the contacts and you get chattering as the door is trying to open or close. It also drains the battery.
The ONLY solution is to replace those door lock switches. I have to do it on my son's 2002 SL2 as he was getting the chattering.
Luckily those switches are only about $20.00+/- to buy and easy to replace. Here's a video I found
https://www.youtube.com/watch?v=EhPaxeq4q8w
aftermarket remote keyless entry maybe remote start rinyotsu L-Series Tech 6 07-02-2016 12:20 PM
remote entry lenmcdade S-Series Tech 3 05-03-2011 08:38 AM
Remote entry? samsr S-Series Tech 41 01-08-2008 08:21 AM
ran over my remote keyless entry, HELP PLEASE!!!!... distortd6 S-Series Tech 6 06-06-2007 10:08 AM
No remote entry Mi_boy Vue General 5 10-16-2006 01:38 AM
