Old 05-10-2018, 06:40 PM   #1
Commeatus
Commeatus is on a distinguished road
1998 SW2
1997 SW2
Default 2nd gen led dash light question
I can't find the old 2nd gen dash thread, all the links are dead, and all my other searches came up empty.
It seems like I can just replace the lights in the instrument cluster with any wedge leds that fit, more or less. Is this true? 98 sw2 if it matters.
Add to Commeatus's Reputation
Rate the quality of this post and help Commeatus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Commeatus is offline   Reply With Quote
Old 05-10-2018, 07:18 PM   #2
Default Re: 2nd gen led dash light question
Yes and no. The base must be correct and do not replace the odometer bulb with an LED if you have the digital odometer.
http://www.saturnfans.com/forums/sho...d.php?t=154964
List of all bulb colors that have the BEST results and if you read to the end I list the bulb type from superbright that fits best and does not tear up the foil, high output T1.5 bulbs. http://www.saturnfans.com/forums/sho...=136986&page=3
All you need to know.
Old 05-11-2018, 09:48 AM   #3
Nekomimi
Nekomimi is on a distinguished road
Nekomimi's Avatar
1996 SL1
So the analog odometer is ok to replace with an led?
Also I've been hunting for this information before and had no luck, thank you ^ .^
'96 SL1 Originally the family car, passed on to me as my first. "Hellcat" 240,000+ miles and purring smooth.
My Mug is filled with the lost souls of imports.
Add to Nekomimi's Reputation
Rate the quality of this post and help Nekomimi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nekomimi is offline   Reply With Quote
Old 05-11-2018, 10:22 AM   #4
Yes, the mechanical odometer should function fine with an LED. The problem is the digital odometer has a solid state dimmer circuit that is always active and is also controlled electronically for a lights on dim condition and is not controlled by the dimmer bus. The LED does not draw sufficient current for it to function correctly and it eventually fails to either full 12v bright or zero. If you change al bulbs to LED you will have a lifetime supply of incandescent odo bulbs.
Old 05-11-2018, 11:20 AM   #5
lol, never thought of it that way
Don's bulbs is no longer active and Don retired, but I posted some info a while back on the difference between 73 and 74 incandescent bulbs from his site. Post 8, in this thread
http://www.saturnfans.com/forums/sho...d.php?t=184447
The 74LL was rated at 500 design hours. Other sites show the same hours
http://www.bulbconnection.com/ViewSI...1355/item.html
Rated Average Life
500 hrs
I changed my odo bulb back in 6/2010 with a 74LL
http://www.saturnfans.com/forums/sho...d.php?t=154888
Thought I would have to be changing the odo bulb again soon, but the bulb is still going strong after 7 years (conservatively estimated over 1,500 hours)
So yeah, at that rate . . . if I convert to LED on the SL2, that is definitely a lifetime supply
alordofchaos is online now   Reply With Quote
Old 05-11-2018, 12:55 PM   #6
Nekomimi
Nekomimi's Avatar
1996 SL1
Just asking to be sure since I saw it was mentioned in the other thread, would the bulbs be the same for earlier gen2, like 96?
Old 05-11-2018, 01:25 PM   #7
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
These bulbs work in Gen 1 and 2...
Comes with the bulb base/socket...
https://www.superbrightleds.com/more...panel-led/709/
You must remove the old bulb from the base, and reuse the base...
https://www.superbrightleds.com/more...rofit-car/228/
NGK BKR6E-11 spark plugs
Old 05-11-2018, 08:34 PM   #8
The T-1.5 or the PC74 in first link above will both work. Look at the base diagrams with dimensions on the Superbright site, the base interchanges. That T-1.5 specifies a bulb shape, or used to, now it is just diameter and length. The PC 73 or 74 specifies a base and a bulb shape, or used to. Then look at he beam angles and lumen intensity. Keep in mind that every single one of the white letter an general lights have a blue diffusion shield and only the 6000K white LEDs will work without hot spots and very low output.
Yes, either works in a 96.
Old 05-11-2018, 10:39 PM   #9
Waiex191
Waiex191's Avatar
I ended up buying incandescent bulbs from Amazon. It was cheap. Downside: what if they only last another 18 years?
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 05-11-2018, 10:50 PM   #10
Commeatus
1998 SW2
1997 SW2
Thanks everyone!
Old 05-12-2018, 02:59 PM   #11
Grungi
Grungi is on a distinguished road
1998 SL
2007 AURA XR
I am replacing my gen2 IP bulbs too. Thank you for the on going discussion about this topic.
I ordered the colored PC74 leds as suggested in other threads. Odometer bulb will remain as incandescent. I may replace it with new while the IP is out.
I have to concern some so far. The red indicators (brake, battery, seatbelt, etc.) illuminate as expected using the red PC74 led but have a slight glow afterwards. I do not like the effect.
The gauge backlights seem to have soft spots using the white PC74 when inspecting the effects around sunset. If had to do it again, I may have chosen 74 led for the greater light pattern - 3 leds vs 1 led).
I had to replace the column switches because the hazards and the Hi beam contacts wouldn’t switch to verify the Hi Beam indictator turned on. The intermittent wipers were also more intermittent and would only turn off when the car was turned off the circuit dissipated regardless of setting. The wipers remained on whenever the car was turned right away. Spent an hour at Pick n Pull for parts. The connector to the turn signal switch was melted. Thankfully the car has been parked with the battery disconnected for a year.
I noticed the AC, recirc, and lighter indicator bulbs do not illuminate. More to come with that later.
'98 SL - 299k
'99 SL1 - 211k
'07 Aura XR - 121K
Add to Grungi's Reputation
Rate the quality of this post and help Grungi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Grungi is offline   Reply With Quote
Old 05-12-2018, 06:01 PM   #12
The t-1.5 and the PC 74 LEDs have different current characteristics and that is what causes that slight after glow. The hot spots are caused by a narrow beam angle go for the wide angle. The t1.5 only have an dim after glow on ABS and sometimes the battery light
Old 05-12-2018, 08:08 PM   #13
Nigey
Nigey is a jewel in the roughNigey is a jewel in the roughNigey is a jewel in the rough
2007 AURA XE
Don't mean to hijack the thread, but..... a quick question: I replaced my odometer bulb with an LED on my 2002 gen 3, and I seem to recall I read it came equipped with an LED -but it is a digital odometer. When I replaced it, I never really looked at the old bulb to see if it was LED or not.
Are gen 3 odometers OK to have LEDs?
2007 Saturn Aura XE 3.5 L LZ4 V6
2002 Saturn SL2 1.9L (manual)
Add to Nigey's Reputation
Rate the quality of this post and help Nigey reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nigey is offline   Reply With Quote
Old 05-13-2018, 09:22 AM   #14
Probably, there is a rather lengthy post regarding the gen-3 cluster, I would read that for confirmation.
Old 05-13-2018, 10:28 AM   #15
Grungi
1998 SL
2007 AURA XR
I had a chance to view the instrument panel at night for the first time. The soft areas are only visible during the day. Once I figure out how to upload the picture from a mobile device, I will post it. The car is on the road.
File Type: jpg CC895F4A-059B-45F8-90E8-F1677372D2FF.jpg (85.2 KB, 22 views)
'98 SL - 299k
'99 SL1 - 211k
'07 Aura XR - 121K
Old 05-13-2018, 05:53 PM   #16
Nekomimi
Nekomimi's Avatar
1996 SL1
It's so pretty o .o <3
Old 05-16-2018, 01:12 AM   #17
Catch-TwentyTwo
Catch-TwentyTwo is a jewel in the roughCatch-TwentyTwo is a jewel in the roughCatch-TwentyTwo is a jewel in the rough
Will they work in a 3rd gen 2002 SL2? I want to change the original lights to the blue LED's on that website. Also with the original lights, are the bulbs in color (red for the parking brake)or are they all white?
How many lights are needed of each type?
Add to Catch-TwentyTwo's Reputation
Rate the quality of this post and help Catch-TwentyTwo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Catch-TwentyTwo is offline   Reply With Quote
Old 05-16-2018, 07:47 AM   #18
Uh... "The definitive guide to Gen3 S-series instrument cluster bulb replacement"
LED Dash light question sc2 saturn S-Series General 1 06-04-2016 06:49 AM
random dashboard flicking , radio dash light out, cigarette bulb light out hlouis89 S-Series Tech 13 03-22-2014 04:27 PM
What does this light on the dash mean? Jonathan 2.4 L-Series General 4 02-20-2007 03:19 PM
Dash light bulb failure question ken b. S-Series General 1 12-14-2006 11:56 AM
Question about Airbag dash light! redkees@msn.com S-Series Tech 4 08-26-2006 12:36 PM
