#1 | ||||
![]() Join Date: Jun 2017
![]() I've been experiencing a rough idle, fluctuating between 500-600RPM, when I'm stopped at a traffic light or just stuck in the bank drive thru. When I put the car in park, the engine revs up to a constant 1100 RPM with no roughness at all. I get two codes. P0446-Evaporative Emission Vent System Performance and P0507 - Idle Speed High. The dealer performed a vacuum smoke test and found no leaks. I also replaced the gas cap and IAC valve, and cleaned the throttle body. Any suggestions on what I can try next?
#2 | ||||
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2010
![]() OK, so when you cleaned the throttle body and replaced the IAC, did you clean/replace the TPS since you had it all opened up, and did you get all gaskets back in correctly at reassembly?
#3 | ||||
![]() I did replace the TPS also. And yes, all the gaskets were properly seated with no folds when I reassembled everything.
2002 SL1 Rough idle in 1st gear | SILVER2002SL1 | S-Series Tech | 5 | 03-09-2011 05:49 PM |
Rough idle/chirping noise when stopped in gear | SLoneDC | S-Series Tech | 3 | 07-02-2007 06:21 PM |
Rough idle when stopped and in Drive | raiderfan | S-Series Tech | 4 | 07-21-2006 06:39 PM |
Rough Idle Stopped in Drive | thebidsnyper | S-Series General | 16 | 01-04-2006 07:06 PM |
Rough idle when stopped on an incline. | Phrosty3 | S-Series Tech | 1 | 02-27-2002 01:19 PM |
