Old 01-15-2013, 05:39 PM   #61
OdieTurbo
OdieTurbo is on a distinguished road
OdieTurbo's Avatar
2005 VUE 2.4L
Default Re: Cranks for a long time before starting
Originally Posted by bnelson10 View Post
I still have that same problem even though my car starts right up. and the heater core, and thermostat are fairly new and rad has been flushed somewhat recently. not to change the subject of the thread but if i could pick your brain i was wondering where you might start with something like this?
sidenote: this heat problem usually only happens in the colder weather like your no start problem.
I was gonna double-check the thermostat, make sure it's opening at the right temp then I was gonna check the heater core for flow. If the hose going in is warm and the hose coming out is cold, the heater core is plugged up.
Current:
2005 Saturn VUE 2.2L 5-Speed FWD
2002 Saturn SL1 1.9L Automatic
Past:
2002 Saturn SL1 1.9L Automatic (Sold to Sister-In-Law)
2001 Saturn SL1 1.9L 5-Speed (Transmission grenaded twice)
Add to OdieTurbo's Reputation
Rate the quality of this post and help OdieTurbo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OdieTurbo is offline   Reply With Quote
Old 01-16-2013, 12:26 PM   #62
bobyjones
bobyjones is on a distinguished road
Originally Posted by OdieTurbo View Post
When I start it by unplugging the IAC then plugging the IAC back in, it immediately lowers the RPM to about 1,200.
you gotta love these smart whipper snappers
Add to bobyjones's Reputation
Rate the quality of this post and help bobyjones reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bobyjones is offline   Reply With Quote
Old 01-16-2013, 05:39 PM   #63
OdieTurbo
OdieTurbo's Avatar
2005 VUE 2.4L
I think the point of that was that if I disconnected the IAC, the car would start. By reconnecting it and it immediately lowered the RPMs, it indicated that it was working properly.
Current:
Past:
Old 01-17-2013, 12:33 PM   #64
bnelson10
bnelson10 is on a distinguished road
bnelson10's Avatar
OdieTurbo thanks. hopefully i'll be able to check one or the other out this weekend. again, good luck with your troubles.
Add to bnelson10's Reputation
Rate the quality of this post and help bnelson10 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bnelson10 is offline   Reply With Quote
Old 01-16-2016, 12:55 PM   #65
White Hot
White Hot is on a distinguished road
White Hot's Avatar
1999 SC2
Sorry to try and resurrect this thread....but has anyone ever discovered the "cranks forever when it's cold out and eventually catches after 10+ minutes of cranking" solution? I've been around s series for 8 years, have done countless hours work on over 20 saturns. I know all the ECTS, NGK plugs, t-stat, cleaning ignition module, cleaning TB, ect...tricks. But have yet to figure this one out. Only happens below 30F, and it not readily repeatable. Car is 100k miles 96 SL2 auto. Have replaced:
Ects
Ects pigtail
CPS
NGK plugs
Wires
Egr, tb, tps, and IAC are thoroughly cleaned every oil change (3000 miles)
Fuel pressure is good
Spark is good
Grounds are all good
Plugs are wet when the issue occurs
Battery and alt are new
Have had the issue 4 times in 4 years. The first 3 were within the first 4 months. I'm at a loss.
Add to White Hot's Reputation
Rate the quality of this post and help White Hot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
White Hot is offline   Reply With Quote
Old 01-17-2016, 02:39 AM   #66
Compression? A few hard starts may need GM's phrase for flooding, 'clear flood mode'when several starts fails; holding throttle wide open tells the pcm to stop injectors during starting to allow more air to dilute a flooded engine. One or more repeated attempts at wide open throttle should allow a flooded engine to sputter and run.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Engine not starting, cranks, but that is all ChiChi01 L-Series Tech 7 04-11-2010 10:11 PM
Long time, first time post. My brother's saturn mabowden S-Series Tech 13 12-27-2008 07:09 PM
Been a LONG Time!! 2NDSOUT General Saturn Discussion 8 04-11-2005 02:50 AM
Cranks for a while before starting... TIMSPEED S-Series Tech 13 01-27-2005 10:52 AM
Long time viewer...first time poster KPL SC2 S-Series General 5 11-18-2003 05:50 PM
