Old 11-05-2009, 11:18 PM   #1
guting
guting is on a distinguished road
Default Adding new keyless remote to 2007 Vue
I have a question about 2007 Vue Keyless Remote. My Vue came with a keyless remote with the following markings on the back of the remote: GM# 21997127 FCCID LHJ011. I bought two additional new remotes with markings: GM# 15913420 FCC ID: OUC 60270. A couple of web sites sell this type of remote for 2007 Vue. However, my local GM dealer could not program the two new remotes. They were able to remove and add the old LHJ011 remote with Tech II computer. They checked the two new ones and found that they did emit signals.
What is going on? The two new remotes are the wrong type, or should I try again at a Saturn dealership (the nearest one is 1.5 hours away)?
Please give me some suggestions. Thanks!
Add to guting's Reputation
Rate the quality of this post and help guting reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
guting is offline   Reply With Quote
Old 11-07-2009, 11:53 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: Adding new keyless remote to 2007 Vue
Baffling to be sure ... and for what its worth ... my 2005 Vue fobs are numbered same as the "working" one you have.
I've bought several RKE fobs for other vehicles from eBay and guess I've been fortunate as they were programmable to work as advertised - without exception.
It probably has little value for you but I've attached the RKE section from factory service manual. It applies to 2005 Vue but since your fobs have the same number not much appears to have changed.
Old 11-13-2009, 11:02 PM   #3
guting
Thanks for your reply.
I assume you bought additional keyless remotes that are identical to your working one(s) and had them programmed by a dealer. Am I right?
Old 11-14-2009, 01:14 AM   #4
D C
D C is on a distinguished road
D C's Avatar
If your local GM dealer can't manage to get them to work with a Tech2, then going to a Saturn dealer will be no different. and using a Tech2 isn't going to tell them if your remotes are working or not, it's just going to tell them if they're working for your car.
I suspect that if you buy another remote with the same GM part number, it will work.
Add to D C's Reputation
Rate the quality of this post and help D C reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
D C is offline   Reply With Quote
Old 11-14-2009, 11:22 AM   #5
far2grumpy
far2grumpy's Avatar
Actually what I wrote was for "other vehicles" ... I've not tried to add another RKE fob for the 05 Vue.
The "other" fobs were either self-programmable (Dodge minivan), or in case of a Ford pickup, a local locksmith.
IMO the requirement for dealers to complete Vue RKE programming (perhaps same for all newer GM) creates another revenue stream for them.
I accept that for what it is ... we all have to make a living.
Finally, D C offers sound advice - buy a fob with same number as your original and go to any participating GM dealer - I understand all use Tech2.
Good luck!
Old 11-14-2009, 11:21 PM   #6
D C
D C's Avatar
Does anyone know how much a dealer charges to program RKE remotes? It's literally an under 5-minute job.
Old 11-15-2009, 08:18 PM   #7
300maximilien
300maximilien is on a distinguished road
300maximilien's Avatar
2002 VUE 3.0L
Depends...mine does it for free.
Add to 300maximilien's Reputation
Rate the quality of this post and help 300maximilien reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
300maximilien is offline   Reply With Quote
Adding Remote Keyless Entry KoolVue Ion Tech 6 04-01-2010 09:40 PM
2006 VUE Keyless Remote kornholyo_1968 Vue General 2 03-30-2009 11:08 PM
08 Vue KeyFob / remote / keyless programming? loly75ddl Vue General 1 04-22-2008 08:11 PM
Adding Aftermarket Remote Keyless Entry sb1920alk Ion General 13 01-07-2006 06:15 PM
Our 2002 VUE needs another keyless remote Dawn Vue General 5 05-16-2004 02:29 AM
