#1 | ||||
![]() Join Date: Oct 2006
![]() Hey all,
Does anyone know what type of gear oil the manual takes for a 2000 SL2? Capacity, weight, GL4/5? I don't have the service manual. Thanks in advance.
#2 | ||||
![]() Automatic tranmission Fluid.
I use Mobil 1 ATF. Old nuc has liked another type....crap I forget the name of it haha ... Current: 95 SC2 Man 97 SL2 Auto 98 SL1 Auto 01 SL1 Man 02 SL1 Man Past: 94 SL2 Man 95 SL2 Man 95 SL2 Man 96 SL2 Auto 97 SL2 Man 98 SL2 Auto 99 SL2 Auto 2010 SCCA Mohud Street Championship-2nd Place
#3 | ||||
![]() Seriously? The manual tranny uses ATF? Wierd.
#4 | ||||
![]() Amsoil Torque-Drive or Allison/Castrol Transynd. Both are in teh $40.00/gal range but you only have to change it once. You get the Amsoil from your local Amsoil dealer and the Transynd from the truck stop.
#5 | ||||
![]() Yep, DO NOT put gear oil in it. ON uses Amsoil Torque-Drive which is originally spec'd for heavy duty Allison transmissions.
Edit: He even beat me to it ![]() ... Former DD: 1994 SC2 5spd. 190K, being sold to a friend 2005 Saturn ION 2 5spd. 73K 1995 Aquamarine SL2 1.9L DOHC 5spd. ~125K Miles
#6 | |||||
How much do I need? (capacity?)
#7 | |||||
#8 | |||||
h t tp://w w w.amsoil.com/storefront/atd.aspx guess I'll just hit the store for good ATF. Thanks guys, you rock! Car's still running strong although it's burning/using more and more engine oil as it gets older. But, we're planning on keeping it till the bitter end so I'm trying to replace as many of the fluids as possible. Last month I was forced to replace all of the dexcool when the radiator bit the dust. ![]()
#9 | |||||
#10 | ||||
![]() The last five vehicles my wife and I have owned, going back 20 years, all manuals, take ATF. Three Fords, a Saturn and a Mitsubishi. I wonder what anymore, besides differentials in RWD/4x4 vehicles, uses 80wXXX gear oil.
#11 | |||||
suzuki SX4 takes 75W-90 Gl4 gear oil, both toyota mr2's take GL-4 or 5 75W-90 or 80W-90. out of 4 cars, the saturn's the only one that takes ATF.
#12 | ||||
![]() Buy the gallon of Torque - Drive and you can use the leftover in the power steering. You remove the existing oil in the reservoir and refill, drive for a week and repeat 3 or 4 more times. Beats pulling lines.
#13 | ||||
![]() 2.5 quarts? Crap. I think mine just took 3-4
![]() (goes to check stupidly placed dipstick under ABS module...) ... The proper way to fix a S-Series automatic is to replace it with a 5spd O:)
#14 | |||||
![]() ... I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 151k DD 7/2010 Craigslist white 1997 SC2 project 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles
#15 | ||||
![]() The type of oil required is determined by the cut of the gears. The gear oils are about the same viscosity as the other oils at operating temperature. The GL-4 and GL-5 gear oils will remove the clutch material from the synchronizers though. That is the very big reason to not use any GL classified oil in a Saturn transmission. Also avoid the GL-1 spec gear oils as they have no additives at all.
#16 | |||||
![]() Join Date: Aug 2009
"Our most popular and versatile ATF, D4 is suitable for use where Dexron III, Dexron II, or Mercon fluids are recommended. D4 ATF is a fully-synthetic product designed to satisfy the improved low-temperature requirements which will be in the new Dexron IV specification, and the improved shear-stability requirements which will be part of the new Mercon specifications. D4 ATF also provides a GL-4 level of gear protection, making it a superior product for transmissions and transaxles " I hope that doesn't apply to the D4 because I just ordered it. Hopefully you can confirm this before I install the fluid.
#17 | ||||
![]() A "GL-4 level of protection" is not a GL-4 specification lubricant. They are making an oblique reference to the high film strength of a synthetic lubricant. Royal Purple is a 100% PAO synthetic oil. The D4 will be a good synthetic direct replacement for the plain ATF. If that does not prove satisfactory performance ther are other lubes from other sources that just might.
Of course its all just oil and use what ever you want as its all the same. ![]()
Synthetic transmission fluid for 2000 SL1 manual | pimpin88 | S-Series Tech | 1 | 12-09-2009 05:59 PM |
2000 SL2 transmission fluid change question! | indy440 | S-Series General | 11 | 06-04-2009 06:41 PM |
Can an 2000 SC2 bumper hook up to a 2000 SL2? | plastic torpedo | S-Series Mods | 2 | 08-07-2007 01:55 PM |
2000 sl2 transmission fluid | mesfish | L-Series General | 0 | 12-09-2004 11:46 PM |
Auto Tranny Fluid Change on 2000 LS2 | filter905 | L-Series General | 13 | 09-12-2004 04:39 PM |
