Old 08-11-2009, 01:46 PM   #1
JaeMarie
JaeMarie is on a distinguished road
Default MT fluid for 2000 SL2?
Hey all,
Does anyone know what type of gear oil the manual takes for a 2000 SL2?
Capacity, weight, GL4/5? I don't have the service manual.
Thanks in advance.
Add to JaeMarie's Reputation
Rate the quality of this post and help JaeMarie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JaeMarie is offline   Reply With Quote
Old 08-11-2009, 01:54 PM   #2
rc1488
rc1488 has a spectacular aura aboutrc1488 has a spectacular aura about
rc1488's Avatar
Default Re: MT fluid for 2000 SL2?
Automatic tranmission Fluid.
I use Mobil 1 ATF. Old nuc has liked another type....crap I forget the name of it haha
Current: 95 SC2 Man 97 SL2 Auto 98 SL1 Auto 01 SL1 Man 02 SL1 Man
Past: 94 SL2 Man 95 SL2 Man 95 SL2 Man 96 SL2 Auto 97 SL2 Man 98 SL2 Auto 99 SL2 Auto
2010 SCCA Mohud Street Championship-2nd Place
Add to rc1488's Reputation
Rate the quality of this post and help rc1488 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rc1488 is offline   Reply With Quote
Old 08-11-2009, 01:57 PM   #3
JaeMarie
Seriously? The manual tranny uses ATF? Wierd.
Old 08-11-2009, 02:03 PM   #4
Amsoil Torque-Drive or Allison/Castrol Transynd. Both are in teh $40.00/gal range but you only have to change it once. You get the Amsoil from your local Amsoil dealer and the Transynd from the truck stop.
Old 08-11-2009, 02:04 PM   #5
Col.FUBAR
Col.FUBAR is on a distinguished road
Col.FUBAR's Avatar
1994 SC2
Yep, DO NOT put gear oil in it. ON uses Amsoil Torque-Drive which is originally spec'd for heavy duty Allison transmissions.
Edit: He even beat me to it
Former DD: 1994 SC2 5spd. 190K, being sold to a friend
2005 Saturn ION 2 5spd. 73K
1995 Aquamarine SL2
1.9L DOHC 5spd. ~125K Miles
Add to Col.FUBAR's Reputation
Rate the quality of this post and help Col.FUBAR reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Col.FUBAR is offline   Reply With Quote
Old 08-11-2009, 02:04 PM   #6
JaeMarie
thanks, I was about to place an amsoil order so figured I'd ask.
How much do I need? (capacity?)
Old 08-11-2009, 02:06 PM   #7
Col.FUBAR
Col.FUBAR's Avatar
1994 SC2
The manual trans should only take 2.5L and I believe it says on the dipstick (but it will say in the owners manual for sure) I'm pretty sure the smallest quantity of torque-drive you can buy is 1 gallon or 3.79L. You can use the extra torque-drive in the power steering pump (remove as much old P/S fluid as possible from the reservoir with a turkey baster )
1995 Aquamarine SL2
Old 08-11-2009, 02:12 PM   #8
JaeMarie
you are correct:
h t tp://w w w.amsoil.com/storefront/atd.aspx
guess I'll just hit the store for good ATF. Thanks guys, you rock!
Car's still running strong although it's burning/using more and more engine oil as it gets older. But, we're planning on keeping it till the bitter end so I'm trying to replace as many of the fluids as possible.
Last month I was forced to replace all of the dexcool when the radiator bit the dust.
Old 08-11-2009, 02:15 PM   #9
Col.FUBAR
Col.FUBAR's Avatar
1994 SC2
you are correct:
MAKE SURE it is Dexron III ONLY. The newer Dexrons' (they are on VI I think) have a LOWER viscosity than Dex III and they will cause shifting issues when warm. Your best bet is to find some Mobil 1 Synthetic ATF because that still meets Dex III's viscosity rating and hardly any (if any at all) "dino oil" based ATF is Dex III only.
1995 Aquamarine SL2
Old 08-11-2009, 02:42 PM   #10
madpogue
1996 SW2
The last five vehicles my wife and I have owned, going back 20 years, all manuals, take ATF. Three Fords, a Saturn and a Mitsubishi. I wonder what anymore, besides differentials in RWD/4x4 vehicles, uses 80wXXX gear oil.
Add to madpogue's Reputation
Old 08-11-2009, 03:02 PM   #11
JaeMarie
it's the odd man out @ our house.
suzuki SX4 takes 75W-90 Gl4 gear oil, both toyota mr2's take GL-4 or 5 75W-90 or 80W-90. out of 4 cars, the saturn's the only one that takes ATF.
Old 08-11-2009, 03:27 PM   #12
Buy the gallon of Torque - Drive and you can use the leftover in the power steering. You remove the existing oil in the reservoir and refill, drive for a week and repeat 3 or 4 more times. Beats pulling lines.
Old 08-12-2009, 03:06 PM   #13
2.5 quarts? Crap. I think mine just took 3-4
(goes to check stupidly placed dipstick under ABS module...)
Old 08-12-2009, 03:33 PM   #14
Guessing the SX4 is AWD or 4WD? and the MR2s are RWD, and madpogue suggested these are what typically use the gear oils
Old 08-12-2009, 03:51 PM   #15
The type of oil required is determined by the cut of the gears. The gear oils are about the same viscosity as the other oils at operating temperature. The GL-4 and GL-5 gear oils will remove the clutch material from the synchronizers though. That is the very big reason to not use any GL classified oil in a Saturn transmission. Also avoid the GL-1 spec gear oils as they have no additives at all.
Old 08-12-2009, 05:23 PM   #16
mjoekingz28
mjoekingz28 is on a distinguished road
The GL-4 and GL-5 gear oils will remove the clutch material from the synchronizers though. That is the very big reason to not use any GL classified oil in a Saturn transmission..
"Our most popular and versatile ATF, D4 is suitable for use where Dexron III, Dexron II, or Mercon fluids are recommended. D4 ATF is a fully-synthetic product designed to satisfy the improved low-temperature requirements which will be in the new Dexron IV specification, and the improved shear-stability requirements which will be part of the new Mercon specifications.
D4 ATF also provides a GL-4 level of gear protection, making it a superior product for transmissions and transaxles "
I hope that doesn't apply to the D4 because I just ordered it. Hopefully you can confirm this before I install the fluid.
Add to mjoekingz28's Reputation
Rate the quality of this post and help mjoekingz28 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mjoekingz28 is offline   Reply With Quote
Old 08-12-2009, 08:41 PM   #17
A "GL-4 level of protection" is not a GL-4 specification lubricant. They are making an oblique reference to the high film strength of a synthetic lubricant. Royal Purple is a 100% PAO synthetic oil. The D4 will be a good synthetic direct replacement for the plain ATF. If that does not prove satisfactory performance ther are other lubes from other sources that just might.
Of course its all just oil and use what ever you want as its all the same. /SNARK
Synthetic transmission fluid for 2000 SL1 manual pimpin88 S-Series Tech 1 12-09-2009 05:59 PM
2000 SL2 transmission fluid change question! indy440 S-Series General 11 06-04-2009 06:41 PM
Can an 2000 SC2 bumper hook up to a 2000 SL2? plastic torpedo S-Series Mods 2 08-07-2007 01:55 PM
2000 sl2 transmission fluid mesfish L-Series General 0 12-09-2004 11:46 PM
Auto Tranny Fluid Change on 2000 LS2 filter905 L-Series General 13 09-12-2004 04:39 PM
