#1 | ||||
![]() Join Date: Aug 2016
![]() My 97 SC2 is a circle track car. Ported head, Gude race cams, header, Storm throttle body, and Wiseco 13:1 pistons. My question is can I run it with out a Map sensor? The car runs good other than at idle unless the sensor is unplugged. I understand the sensor interprets how much load the engine is at, but it stalls and hunts for a happy place to stay running. I can turn up the idle but then runs too high. Checked for vacuum leaks and none found. And yes I have tried another Map sensor. Any suggestions?
#2 | ||||
![]() You might have the best of two methods if this idea works for you - wire a switch inline to one wire on the sensor. Switch it on or off. This should give you the best of both situations, off when needed and on when needed. As a load sensor, its only for naturally aspirated engines that sucks in air (no turbo or supercharger). Since n/a engines create a vacuum when the engine runs, the 1-bar/atmosphere map sensor measures from near absolute vacuum (29.99in hg) to sea level pressure (14.7psi) hence the 1-bar rating. Turbo and superchargers generate positive pressure above ambient atmospheric pressure so 2 or 3 bar map sensors are needed with factory programming ecm/pcm to detect the change from vacuum to positive pressures, allowing the ecm/pcm to alter the fuel mixtures without creating an extreme lean condition when positive air pressures means more air than fuel results in a blown engine. And if you're thinking of throwing in a 2/3 bar map sensor, you'll screw up the ecm/pcm when its set for 1 bar sensors.
If you have the time, there's something wrong with your setup that's confusing the pcm, creating the problem you're experiencing. If the on/off switch works then you can leave it as is and incorporate the routine of switching the map sensor on/off into your routine for track racing.
#3 | ||||
![]() Thanks for the reply and info. Will it run to lean leaving the sensor unplugged?
#4 | |||||
![]() ![]() ![]() ![]() Join Date: Aug 2016
Is the PCM still stock? What is the lift, duration, and lobe centerline profiles of the camshafts? Unplugging the MAP sensor will default the PCM to fuel maps with reduced power output, because it will cause a DTC. In other words leave the sensor plugged in. You can try a 2-BAR MAP, but this will run the engine WAY TOO rich, and the O2 sensor will set DTCs trying to lean it out with the short term fuel trims. ... "What does a Saturn owner do, at the gas station?" "He checks the gas, and fills the oil....."
#5 | ||||
![]() Engine is just factory injection.
Intake lift .368 Duration 236 degrees Exhaust lift .344 Duration 238 degrees Stock pcm 10-12 in vac @ idle
#6 | ||||
![]() Dunkinboom, here's a good site to learn how map sensors are used; http://www.aa1car.com/library/map_sensors.htm. I'm no expert on EFI systems but know enough to understand there's always a reason for engineers to have parts on our engines. Someone miscalculated and caused deaths when a newly designed walkway was set in place over a six or eight lane road in Florida. It collapsed. Whether the roads should have been closed that day until it was deemed absolutely safe to allow traffic underneath it before it was fully erected remains unanswered until the NHTSA determines where fault lies. NHTSA is very good at finding why commercial airlines crash and preliminary info says the bridge span was already weakened when hoisted into place over the road way. EFI engines relies on every sensor feeding signals to the engine computer to make the right fuel mixtures. Disconnecting the map sensor simply means the engine doesn't have a way to know airflow other than throttle position. It's like having one eye closed. You can see but you loose perspective. Two eyes gives a person three dimensional perspective. One eye doesn't. Disconnecting a map sensor cripples the engine computer. A guess might be leaner fuel mixtures. One eye would be the throttle position sensor, the other eye would be the map sensor.
#7 | |||||
Your vacuum is way too low, due to the camshaft duration. You have a very high-rpm duration. What I recommend is to punch the cover off the adjustment screw for the Geo Storm TB. Underneath it is a set screw that will depress the throttle and increase idle rpm. This will NOT set any DTCs. I would idle your engine between 1800-2400rpm and check vacuum. Vacuum should probably be above 17" Hg @ idle to smooth it out. That engine build should not be idling at the factory default 750rpms, whatsoever. Volumetric efficiency is way to low, because air velocity and volume are way too low to properly pressurize the cylinder. This is why it is stalling and idling poorly. ... "What does a Saturn owner do, at the gas station?" "He checks the gas, and fills the oil....."
#8 | ||||
![]() Sorry to disagree with you but you're wrong with adjusting the throttle stop screw. This is a mechanical setting with the bypass air port blocked to adjust for the initial idle between 500-600 rpm, performed (I presume) at factory assembly. When the bypass air port is unblocked, the EFI system detects the rpm and automatically adjusts the idle air control valve to allow metered airflow from the bypass air port to raise rpm to electronically controlled idle, 650-850 (warm engine). All idle speed control is electronically adjusted with the iacv, not the throttle stop screw. Cold engine running idle is adjusted the same way using the iacv and engine computer. Adjusting the throttle stop screw may raise idle until the pcm can't adjust idle any longer as the pcm knows idle is incorrect and tries to bring it back to programmed idle speed. In this case the cams running lower vacuum means the map sensor is detecting higher air flow (incorrectly) and richens fuel mixtures. Switching off the map sensor then forces the pcm to rely on throttle position.
You are correct to point out a lower than normal vacuum and is probably the reason for a lumpy idle the EFI system can't deal with. This is a modification from factory stock setup, making this engine a custom setup with problems not accounted for in stock setup using stock pcm programming. Since every muscle car now made uses EFI systems, they're tuned long before hitting the assembly lines so owners can just push the pedal and use premium gas without the hassle of tuning. This track car is no longer stock and needs tuning. Normal idle vacuum should be between 15-20 in. As suggested, if switching the map sensor works then this should work in this unusual situation with an easy fix for a track car.
#9 | |||||
This is why you can hit the throttle just a tad, at idle, and rev your engine without the IAC trying to restrict flow or RPM. As the throttle opens, the IAC actually closes a little. ... "What does a Saturn owner do, at the gas station?" "He checks the gas, and fills the oil....."
#10 | ||||
![]() Dunkinboom, if you're certain disconnecting the map sensor allows a decent idle compared to having it connected, I may have a workaround with the switch mod. As Saturn Night noticed from your engine stats, the lower (relative to zero gauge/atmospheric) vacuum compared to normal (higher) vacuum due to cam timing keeping valves open longer for high rpm scavenging but lumpy idle unless rpm is raised interferes with the programmed stock pcm setup. The pcm interprets this low vacuum as throttle opened as in acceleration so its adding more fuel at actual idle rpm resulting in a rich fuel mixture. Thie extra rich fuel and greater valve opening time increases the lumpy idle. Unfortunately, as a one off mod, you become the beta tester, inheriting any issues when altering stock mechanical configurations the pcm isn't programmed to account for. A work around may be wiring a mini leaf switch onto a bracket mounted to the throttle where opening throttle closes the switch.
The leaf switch can be either normally closed/held open or normally closed/held open. You select how it's used on the bracket so the leaf switch triggers open or closed to activate/deactivate the map sensor when opening throttle. The idea here is to have the map sensor switched off at idle/closed throttle, map sensor switched on when throttle is opened. Test the switch setup first to be sure this works before making a bracket and buying a leaf switch. A simple pair of small gauge wires extending into the interior with any on/off switch temporarily held in your hand becomes a test setup while you coordinate switch operation to pedal. If this temporary setup works, you can move forward to making a custom switch bracket to mount a leaf switch to operate with throttle to mechanically operate the switch. Last edited by fdryer; 04-27-2018 at 04:27 PM..
O2 sensor question | joshuabornemann | S-Series Tech | 6 | 02-04-2012 10:33 AM |
02 sensor question | ratwhisperer | S-Series Tech | 4 | 08-12-2010 08:26 AM |
map sensor question | duganator9 | S-Series Tech | 10 | 11-13-2007 01:13 AM |
O2 Sensor question | DeCaff2006 | S-Series General | 2 | 04-18-2006 07:10 PM |
Sensor Question? | Onewest | Miscellaneous Tech | 4 | 02-27-2003 11:37 AM |
