Old 11-10-2018, 08:44 PM   #1
FutureSat
FutureSat has a spectacular aura aboutFutureSat has a spectacular aura aboutFutureSat has a spectacular aura about
2002 L-Series 2.2L Wagon
Default Help to ID valve feed off headers 1.9L SOHC
Recently, I replaced my headers. Yes they fit direct on my 2001 SL1. reason why is because I needed to replace the CAT and I went with a stainless steel straight pipe for basically the same cost for the part.
however, it wasn't an exact match to the OEM headers. there is some type of tap off from the headers that feeds some type of valve/sensor. ATM i put the new headers on and the car is running without this valve hooked up.. IDK what valve this is I'm looking at manuals. any help? is this important.. IDK b/c the OEM headers have a underside exhaust vane/vine that was clogged with carbon build up when i took off the old OEM headers that feeds this tap off exhaust pipe to this sensor..
Advise, Help to id.. if it is important or if i can delete it. IDK
Thanks
File Type: jpg Screen Shot 2018-11-10 at 7.38.43 PM.jpg (78.8 KB, 14 views)
Add to FutureSat's Reputation
Rate the quality of this post and help FutureSat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FutureSat is offline   Reply With Quote
Old 11-10-2018, 08:58 PM   #2
trottida
trottida's Avatar
Default Re: Help to ID valve feed off headers 1.9L SOHC
That is the air injection system; part of the emissions system. You'll get some codes and a service engine soon light without it hooked up.
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 11-11-2018, 06:19 PM   #3
FutureSat
Thanks, Code that popped up is the P0301.
I will have to figure out a solution to this. IDK at the moment.
Old 11-11-2018, 07:12 PM   #4
laser3kw
laser3kw is on a distinguished road
2000 SC1
Did your old header have the connection?
Here is some screen shots of a header with the connection port. The flange side shows the port path from the tubes to the connection port. You could make a manifold to connect to the air pump output and splits to the header tubes. It would take some welding skills.
Add to laser3kw's Reputation
Rate the quality of this post and help laser3kw reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
laser3kw is offline   Reply With Quote
Old 11-26-2018, 09:18 PM   #5
FutureSat
Awesome, Thanks for those photos. This looks possible. weld skills and taking car off the road for a bit to do it. sucks that they didn't come like that. paid $450 waste of my money. i don't know how much longer i am going to keep this car anyways.
headers sl1 98 sohc with A/C how does it fits nanotech S-Series Tech 0 11-28-2009 04:59 PM
WTB: 91-92 OEM/OBX/Hotshot SOHC headers 95sohcSC Classifieds 4 07-09-2006 10:09 AM
Dead Horse Beating: SOHC Headers 95sohcSC S-Series Mods 2 07-08-2006 12:37 AM
SOHC Headers? Derekleu S-Series Mods 21 12-21-2005 08:45 PM
91-92 SOHC Headers So_Lo_Saturn S-Series Mods 9 03-09-2005 08:22 PM
