Old 11-10-2018, 11:41 AM   #1
Doug427
Doug427 is on a distinguished road
Default New owner, what common issues and preventative maintenance do I need to do - 2002 SL1
Just bought a new to us 2002 SL1 - standard trans, 1.9L SOHC engine. Overall good shape, it runs good except for a rough idle and popping in the exhaust that I posted about in a separate thread looking for help and ideas.
I've tried to do a bit of searching to see what common issues these cars have that I can address in advance.
I've read about the plastic vs. brass tipped temp probe. Right now the temp shows exactly where I have read it should read, about 2 needle widths left of vertical. Should I change the probe (or whatever acronym it's called) anyway?
I have had to change the drivers side electric door lock switch, which seems to be a common issue. The reverse lights don't work, I have a switch on the way.
Anything else I should be looking at that regularly fails on the car?
Add to Doug427's Reputation
Rate the quality of this post and help Doug427 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Doug427 is offline   Reply With Quote
Old 11-10-2018, 12:50 PM   #2
Default Re: New owner, what common issues and preventative maintenance do I need to do - 2002
Hey Doug427,
Welcome to the forums. This sticky is a good read:
http://www.saturnfans.com/forums/sho...d.php?t=177672
Sounds like you have been doing your research already. Beyond plugs might be worth wires and checking for corrosion under the coil packs. Along my SL2 journey I've also replaced the idle control valve. It used to get wonky on me and would stall.
Edit: I've had an uneven idle in other cars that was due to a worn throttle position sensor.
Add to Waiex191's Reputation
Old 11-10-2018, 01:12 PM   #3
edlee
edlee will become famous soon enoughedlee will become famous soon enough
1999 SL1
You might want to check for rust under the rear door sills.
You might want to check for rust on the driver's side brake line. Salt road spray accumulates on the driver's side brake line in the engine compartment and runs down the line.
Add to edlee's Reputation
Rate the quality of this post and help edlee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
edlee is offline   Reply With Quote
Old 11-10-2018, 01:57 PM   #4
That's the ECTS. No need to change it since you are showing correct temp, and Saturn had changed the ECTS from plastic to brass tipped sometime late in the 2001 model year - so all 2002 S-series are OK there
Oil burning is the #1 thing. Your step son should check the oil (on a flat suface, cold engine) roughly every 250~350 miles at first to get an idea of how much it uses. Top it off immediately rather than letting it get a quart or half quart down. Each diamond mark on the dipstick is 3.2 oz. I'm adding about 6 oz a week right now.
2002 SL1-Auto Trans Preventative maintenance advice wanted quartermil S-Series Tech 7 01-17-2013 11:22 AM
preventative maintenance Q's banman S-Series Tech 3 09-04-2012 03:56 PM
20k Preventative Maintenance? jimsz Ion General 2 03-17-2008 08:44 PM
common maintenance issues saturn4shane S-Series General 25 01-04-2008 08:28 PM
2002 SL1 Preventative Maintenance joecacti S-Series General 3 07-21-2006 12:04 PM
