Old 11-09-2018, 03:07 PM   #1
trottida
trottida's Avatar
Default Late GEN2 Alternator on an Early GEN2?
Can I used a 99 DOHC alternator on a 96 DOHC if I change the plug on the engine harness to match? Any issues or tricks I need to be aware of?
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 11-09-2018, 05:26 PM   #2
Default Re: Late GEN2 Alternator on an Early GEN2?
Nope, they swap with a connector shape change. Google how to wire the adapter so you get the wires in the correct spot. The adapter 130<->121 is a more or less standard part and costs about 15$ from rebuilders.
Old 11-10-2018, 08:03 AM   #3
trottida
trottida's Avatar
Found this adapter but I think I need the opposite as far as male female goes. Do you have a line on the other?
Harness for Alternator Conversion Delco CS130 CS121 to Denso
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 11-10-2018, 09:39 AM   #4
You'll have a hard time finding the full pigtail to go the other direction, all the re-builders will ask why you want to swap the crap alternator for the good one.
I believe they're mislabeled on AlternatorParts.com, says it's for the CS130D even though that's the good alternator while it's got the CS121 plug which is the bad alternator.
https://store.alternatorparts.com/c1...connector.aspx
I don't mean bad as to longevity, the case is smaller and less efficient...less output stock and less room for high output parts (150-250amp) and harder to rebuild due to less working space.
Old 11-10-2018, 09:59 AM   #5
trottida
trottida's Avatar
I'm not having much luck today with Google. Can't find the wiring schematics to change the harness plug from square to oval. Do the wire colours match up? Can anybody help?
I have one available from my parts car; I'm selling the 96 SL2 project car and the alternator is on its way out so I'm going to give the buyer the 99 SL2 alternator, the plug and instructions on how to convert.
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 11-10-2018, 10:10 AM   #6
Look at the square regulator plug and the old CS130D alternator regulator on the side just below the pins you will see P,L,I,S See which wire is connected to what pin, usually S and I. Now look at the CS121 alternator in the same place. Match the proper wire to the correct letter. The only time you get into trouble is when it is a different regulator and you tell this wen 1 alternator has the PLIS regulator and the new one has a different letter or 2 in that series.
Google is just failing this morning...
Old 11-10-2018, 10:14 AM   #7
'97.5+:
pin color function
B brn/wht battery light
C brn VR turn on (key-on powered)
earlier:
pin color function
F brn VR turn on (key-on powered)
L brn/wht battery light
Should work color to color, but verify the functions are in the same places first. Easy way to burn out the VR is to mix those up.
Old 11-10-2018, 10:37 AM   #8
The issue is that the regulator is marked with slightly different lettering for what are identical functions.
The CS121 regulator should have identical pin markings but that different shape connector.
This is a CS130 series with a different regulator. https://imgur.com/WU3ht6x There are several different regulators ...
If the regulators mach it gets real easy. Most/all of the critical info is at this site: https://alternatorparts.com/
Old 11-10-2018, 11:31 AM   #9
trottida
trottida's Avatar
'97.5+:
pin color function
earlier:
pin color function
On the 99 alternator that seems to be the case. The brown/white wire in position B goes to pin L and the brown wire in position C goes to Pin F.
The 96 is still on the car so I'll have to investigate that later.
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 11-10-2018, 11:34 AM   #10
That is the wrong part. Will not work.
Old 11-10-2018, 12:24 PM   #11
Note the double letters on the B wire, I/F. These connect to the matching functions on the other alternator.
Gen2 Dash Rattle trottida S-Series General 7 11-13-2017 02:05 PM
Sat SC gen1 and gen2 spoilers jchu210 S-Series General 2 02-07-2012 12:07 AM
Will a gen2 dash panel (the top) fit a '95 SL2? PlasticCarsRock S-Series Tech 3 09-22-2011 04:46 PM
Almost new Gen2 SL1? KingRex S-Series General 4 02-18-2010 11:03 AM
Steering Wheel Gen3 on a Gen2? WingsOfSaturn S-Series Mods 3 11-14-2006 02:13 PM
