Old 06-19-2012, 08:49 PM   #1
longhornx
longhornx is on a distinguished road
Default A few electrical problems with my 01 SC2
I'm having a few electrical problems with my SC2.
1. The doors can't be locked with the remote, but unlocking works fine. If I press the lock button twice on the remote, it actually actives the "security" light on the dash so I assume the remote is ok. It just won't lock the doors. The lock/unlock switches on both doors work fine though.
2. When the A/C blower switch is set to max, the blower motors runs like it's set to minimum - it blows really slow. Other switch settings are normal - just the maximum doesn't work.
3. The left headlight won't turn on properly. I turn on the headlight switch, usually the left headlight is off. I have to knock on the headlight assembly and then the light turns on. I checked the connector and it seems ok.
Any idea??
Add to longhornx's Reputation
Rate the quality of this post and help longhornx reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
longhornx is offline   Reply With Quote
Old 06-19-2012, 09:13 PM   #2
campus189
campus189 is on a distinguished road
campus189's Avatar
1997 SL1
Default Re: A few electrical problems with my 01 SC2
As far as the remote goes...
Take it apart with a dime & wipe off the membrane & circuit board with a paper towel & put back together.
Headlight is on it's way out, to confirm, switch bulbs to see if that works, if so buy another bulb.
1997 Saturn SL2 144,000 Miles
1997 Saturn SL1 254,000 Miles
1997 Saturn SL1 157,000 Miles
1996 Saturn SL1 97,000 Miles
Also known as FiremanCV on YouTube
Add to campus189's Reputation
Rate the quality of this post and help campus189 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
campus189 is offline   Reply With Quote
Old 06-19-2012, 10:34 PM   #3
ShawnV
ShawnV has a spectacular aura aboutShawnV has a spectacular aura about
ShawnV's Avatar
1996 SW2
2000 SW2
The blower max setting is on its own relay on the interior fuse block. Try switching it with the fuel pump relay then turn your key on. If your blower suddenly works and you don't hear the hum of your fuel pump, replace the relay.
Add to ShawnV's Reputation
Rate the quality of this post and help ShawnV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ShawnV is offline   Reply With Quote
Electrical Problems CptMatt Aura General 16 09-28-2009 07:20 PM
Electrical problems?? 05blueredline Vue Tech 4 07-09-2009 06:09 PM
electrical problems need help cars=bad L-Series Tech 5 03-25-2008 07:29 PM
Electrical Problems jetmech101 S-Series Tech 10 10-25-2005 03:08 PM
electrical problems brotherhay S-Series Tech 2 11-14-2003 07:45 PM
