Old 02-06-2017, 09:06 AM   #1
classic sl
classic sl is on a distinguished road
1998 SL
Default reverse lights issue
so here's the deal. i have a 98 saturn sl with a manual transmission. when i put it in reverse, there's no reverse lights. the reason is because the threads for where the reverse light switch screws in have been stripped. it doesn't screw in far enough to make the connection to whatever part it is that turns em on.
what part do i need to replace to fix this and is it too difficult to do at home?
Add to classic sl's Reputation
Rate the quality of this post and help classic sl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
classic sl is offline   Reply With Quote
Old 02-06-2017, 08:43 PM   #2
gveinot
gveinot is just really nicegveinot is just really nicegveinot is just really nicegveinot is just really nice
gveinot's Avatar
2000 SL2
2000 SL2
Default Re: reverse lights issue
sometimes those Hayes manuals show these types of jobs,
Add to gveinot's Reputation
Rate the quality of this post and help gveinot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-08-2017, 02:03 AM   #3
madpogue
1996 SW2
It's right there on top of the transmission as you've discovered. If you can see that it's stripped, you can reach it to replace it. Let's just hope that it's the threads on the sensor, and not the threads on the tranny case, that are stripped. Replacement should be available at most FLAPS, RockAuto, etc.
Add to madpogue's Reputation
Old 02-08-2017, 10:01 AM   #4
classic sl
1998 SL
unfortunately it's the tranny that stripped. how on earth it happened i have no idea, but hey that's cars i guess im guessing i would have to swap out the entire tranny in this case?
Old 02-08-2017, 10:13 AM   #5
billysvue
JB ( quick)WEld to the rescue( maybe) as long as you first verify the switch does function and it's proper placement does turn on the lights.
THEN GLUE ,not before
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 02-08-2017, 10:28 AM   #6
BV22
2002 SC1
You should try the JB Weld idea above first, and if that fails, another option is to cut the two wires that run to the switch, splice in enough wire to feed through the firewall, and install a toggle switch somewhere in the interior of the car.
Reverse lights would not automatically come on, but you could turn them on when needed. Might not pass muster with the state inspection.
BV22
2002 SC1 5M
RIP Sept 1 2018
315,344 miles
Add to BV22's Reputation
Old 02-08-2017, 10:48 AM   #7
billysvue
HIde the switch Inspector is outside looking for the light to come on- not looking to see if you're turning on a hidden switch, right?
Maybe it's possible to ductape/bind down the existing switch ,tight, to verify the REV lights will come on prior to JBQuick.
'17 Suby Forester
Old 02-08-2017, 10:52 AM   #8
Replace the transmission? Well, that'll make the transmission shop happy but seems rather overkill when the shift tower it's threaded into takes about 5 minutes to take off...lol
I could see running a manual switch (without cutting the current wires) as a temp fix until its above 50f outside to fix it properly but I wouldn't recommend cutting the wires when the "right" fix is as easy as changing a tire.
Old 02-08-2017, 11:25 AM   #9
billysvue
Originally Posted by fetchitfido View Post
Replace the transmission? Well, that'll make the transmission shop happy but seems rather overkill when the shift tower it's threaded into takes about 5 minutes to take off...lol.
Assy you're referring to (view E) is at bottom of parts diagram shown. NOthing, partswise , will spring out to be lost ,or forever stay disasembled, after the 4 bolts ( on the housing that the switch screws into)are removed?
http://www.wholesalegmpartsonline.co...category=19506
'17 Suby Forester
Old 02-08-2017, 11:32 AM   #10
billysvue
If the threads on the (functioning) switch are covered w/ a single wrap of teflon tape, it may be possible to get the JB QUICK to repair the housing threadsand still hold the switch tight, yet still allow the switch to be removed @ a later date, if needed.
'17 Suby Forester
Old 02-08-2017, 12:08 PM   #11
It's mechanically operated, things only move when you play with the linkage the shift cables attach to.
Only thing to be careful of is with the tower removed, there's nothing to stop you from selecting 2 gears at the same time and locking the transmission up until it's returned to 1 gear or less (handy if you need the engine crankshaft not to move).
More info and actual pictures: http://www.saturnfans.com/forums/sho...d.php?t=126905
Reverse issue Jerry52992 S-Series General 8 06-14-2014 12:05 AM
No reverse lights. New bulbs, but no lights. Uthinkso S-Series Tech 5 10-03-2012 03:38 AM
Need help with reverse issue Seerlah S-Series Tech 11 04-06-2012 07:03 PM
Accidentally burned out instrument panel lights and reverse lights on '99 Saturn Sc1 tjohnny42 S-Series Tech 19 07-09-2008 10:40 PM
reverse lights issue sr71000 S-Series General 3 11-25-2007 05:01 PM
