Old 04-13-2019, 10:01 PM   #1
TGP Z-34 STe
TGP Z-34 STe is on a distinguished road
1994 SL2
2005 ION-2 Sedan
Default Many Codes - Misfire - Loss Power
Gray 2005 Saturn Ion II (2.2L, Manual, ABS/Trac)
My wife was driving my gray Ion. Out of the blue driving down the freeway it lost power. Almost sounded like misfire, really rough idle. We swapped cars and when I drove it, I noticed the loss of power right away. Around ~2200 RPM it would feel more back to its normal power, but not completely. I could get it up to 70mph but it was weak, I had to leave it in 4th gear.
If I leave it to idle long enough the engine light will stay on. But if I hit the throttle (moving or parked) it will start blinking rapidly.
The engine light has been on since I bought it. The code was a bad cat but I have never bothered to replace it, as it seems to run just fine. The guy I bought it from sold it for the same issue that I am having now. He tried to fix it but gave up and left it sit for a year. When I started it up to test drive it, it was running like normal. I bought it at 119k miles and it has 146k now, and now this same problem came back.
So far what I have checked….
Fuel Pressure - 54-58 PSI
Fuel Injector – 14 OHM (seems to have a weird reading)
Compression – varies but mostly at 210 PSI
Switch parts with my teal Ion
ICM/Coil and Spark plugs on teal Ion, runs fine.
I don’t know what else to check. Anything you recommend?
The only weird thing I’ve noticed is that when I took the spark plugs out of my gray ion (the one I’m having this issue with) one of the spark plugs is wet, on 4 (by the transaxle end). I put it in my teal Ion and drove it for a half a mile. Took it out and all 4 are dry. What could cause that?
I got 16 codes, bottom is first to top is the last. I don’t what is these mean. History, currently history,Intermittent, Comfirmed, Pending.
P0496 - Evaporative Emission System High Purge Flow - Pending
P0442 - Evaporative Emission System Leak Detected (Small Leak) - Pending
P0420 - Catalyst System Efficiency Below Threshold Bank 1 - Pending
P0304 - Cylinder 4 Misfire Detected - Pending
P0496 - Evaporative Emission System High Purge Flow - Confirmed
P0442 - Evaporative Emission System Leak Detected (Small Leak) - Confirmed
P0420 - Catalyst System Efficiency Below Threshold Bank 1 - Confirmed
P0304 - Cylinder 4 Misfire Detected - Confirmed
P0138 - Oxygen Sensor Circuit High Voltage Bank 1 Sensor 2 - Confirmed
P0496 - Evaporative Emission System High Purge Flow - Current History MIL
P0442 - Evaporative Emission System Leak Detected (Small Leak) - Current History MIL
P0455 - Evaporative Emission System Leak Detected (Gross Leak/Flow) - Intermittent
P0420 - Catalyst System Efficiency Below Threshold Bank 1 - Current History MIL
P0300 - Random - Multiple Misfire Detected - Current History MIL
P0138 - Oxygen Sensor Circuit High Voltage Bank 1 Sensor 2 - History
U1064 - Lost Communication With Body Multiple Control (BCM) - History
(Bottom is start to top is end)
Add to TGP Z-34 STe's Reputation
Rate the quality of this post and help TGP Z-34 STe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TGP Z-34 STe is offline   Reply With Quote
Old 04-18-2019, 01:44 AM   #2
Samtherecordman
Samtherecordman is on a distinguished road
Samtherecordman's Avatar
2007 ION-3 Quad Coupe
Default Re: Many Codes - Misfire - Loss Power
Reset all the Codes
Then
Come back to us with a new list!
Saturn Ion 3 Quad Coupe 3 with Sports Appearance package with Aura Pro Bass Shakers under the front seats, Kenwood Excelon Mono Amplifier and Infinity Kappa Perfect and I'm In Heaven!!!!
Add to Samtherecordman's Reputation
Rate the quality of this post and help Samtherecordman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Samtherecordman is offline   Reply With Quote
Old 06-11-2019, 11:35 AM   #3
TGP Z-34 STe
1994 SL2
2005 ION-2 Sedan
It was Clogged Fuel Injectors.
I have shop installed 4 new injectors. And I did sent back for misfire/loss power again. They just switch injector from number 3 and 4 cylinder. Problem go away. I suspect problem was my bad harness?
Time will tell. That's all for now.
Intermittent loss of power, no codes cdinges S-Series Tech 20 03-07-2018 01:32 AM
lots of codes/ABS loss, power steering loss Burgandy25 Astra Tech 1 01-30-2014 05:34 PM
Saturn Ion tricky misfire/loss of power mrclean235 Ion Tech 6 08-20-2013 10:08 AM
98 SL2: Loss of power, Misfire, stumbling, 4k rev limit, timing chain related? 800xl S-Series Tech 23 12-20-2012 09:52 PM
loss of power, misfire? no code, no ses appears jcm22 S-Series Tech 5 08-02-2007 12:42 AM
