Old 06-28-2020, 08:46 PM   #1
GTSRider
GTSRider is on a distinguished road
Default 2003 ION stalls at stop sign...otherwise....
My 2003 ION runs great in every way..... but stalls
at stop signs , and in any parking lot situation....it is
down right dangerous !
I have replaced IAC & TPS......cleaned out throttle body, &
IAC ports...but still does it ! Funny thing is.... not all the time ,
and only when at full hot operating temps... not when cold....
So....what's up ?
SHOULD I REPLACE FUEL INJECTORS ?
Can't think of anything else ?
Peter
2003 ION 230,000 miles
Hudson Valley , N.Y.
GTSRider is offline   Reply With Quote
Old 06-29-2020, 12:46 PM   #2
Default Re: 2003 ION stalls at stop sign...otherwise....
At 203k miles, age and mileage related issues to long term parts are often forgotten about. Long out of warranty, did you check fuel pressure. Clogged fuel filter? Monitoring pressure while driving may reveal whether or not its on its last legs since no one can tell when a pump begins to fail intermittently.
One member heeded advice (higher mileage than yours), didn't notice fuel pressure issues first time around until it was suggested to leave the pressure gauge connected and check it the moment the engine randomly dies. He found the next check with the needle bouncing wildly. New pump fixed his problem.
How's compression?
2001 Saturn Ls2 will die when you stop at stop sign or light vikasevan L-Series Tech 5 07-07-2017 01:19 AM
SL2 stalled out at stop sign. Stalls below 1500 RPM Need help my only car. ZepSL2 S-Series Tech 4 07-13-2012 08:51 PM
cylinder 3 misfire + a/c when at stop light/sign jhonky S-Series Tech 6 06-07-2011 11:53 AM
Stalls when idle or come to stop... Aztek_SC2 S-Series General 6 12-10-2007 08:48 PM
93 sw2- stalls at stop once warm ndsaturn S-Series General 2 09-14-2004 03:45 AM
