Old 03-12-2008, 09:44 PM   #1
donaldwebster
donaldwebster is on a distinguished road
Default AM Radio Problem AURA 2007 XE
When on AM Band, sometimes the signal almost dies, very weak only picks up stations with 5 miles. This is intermittent, when it happens I can turn the rear window defogger on and the AM pops back to normal, 8 out 10 times this works. It may be good for a long time. It even does this if the car is not moving, so that should eliminate vibration causing it.
When it is screwed up the FM band is normal, does not effect it.
The dealer has updated the computer in the car. But it still happens.
Any ideas, the only thing I can think of is the radio is bad...
Add to donaldwebster's Reputation
Rate the quality of this post and help donaldwebster reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
donaldwebster is offline   Reply With Quote
Old 03-13-2008, 01:06 AM   #2
WopOnTour
WopOnTour will become famous soon enough
WopOnTour's Avatar
Default Re: AM Radio Problem AURA 2007 XE
If the last 8 digits of your VIN is earlier (lower) than 7F257130 there is a TSB #07-08-44-006A for reprogramming the radio for an AM reception issue.
There are also a couple of other generic GM TSBs (not Aura specific) That references details for diagnosis & repair of radio issues involving the rear defrost system. On "some" Auras (those without U71 option) the AM antenna is integral with the rear defrost grid system
HTH
WopOnTour
Add to WopOnTour's Reputation
Rate the quality of this post and help WopOnTour reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WopOnTour is offline   Reply With Quote
Old 03-13-2008, 09:20 AM   #3
bc3tech
bc3tech will become famous soon enough
bc3tech's Avatar
2007 AURA XR
What's AM?
+rep always appreciated!
The Procharged Ion - http://kickassion.bc3tech.net
16.317s @ 85.30mph (Nearly stock)
188.28whp / 175.03wtq - SMP Stage 2 - 10psi
Add to bc3tech's Reputation
Rate the quality of this post and help bc3tech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bc3tech is offline   Reply With Quote
2007 Aura XR won't start (sporadic problem, not a dead battery)) TN1 Aura General 21 10-03-2018 02:29 PM
2007 Saturn Ion Radio problem dpeppe Ion General 5 09-08-2012 05:56 PM
2007 Aura XE brake light problem 2Lime4U Aura General 18 12-17-2011 08:27 PM
Add XM to 2007 Aura factory radio installed donaldwebster Aura General 2 12-17-2007 02:25 PM
New Aura Radio Problem cottage Aura General 54 01-03-2007 04:26 PM
