Old 06-20-2006, 09:26 PM   #1
SilverRush
SilverRush is on a distinguished road
Dizzy '93 SL1 New Battery Drain
A new battery did not cure the problem of draining power. Upon a closer inspection, the center console was ticking and the motorized belt system is not working. The chime is also off/on but mostly chiming. Is the black electrical module in the center console used only for chimes or does it have more than one function?
Add to SilverRush's Reputation
Rate the quality of this post and help SilverRush reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SilverRush is offline   Reply With Quote
Old 06-20-2006, 09:44 PM   #2
brotherhay
brotherhay is on a distinguished road
Default Re: '93 SL1 New Battery Drain
that is exactly what it is. You spilled a Mt. Dew in there an now its malfunctioning, i did the same thing, ha. Im sure these things can be replaced, and im sure someone here will tell you how much they are too. i just got the auto belt set to the rear position, popped the console, pulled the plug to the relay for the belts and put the console back together. Thats the cheap way to fix it, just have to put your belts on manually now.
Add to brotherhay's Reputation
Rate the quality of this post and help brotherhay reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
brotherhay is offline   Reply With Quote
Battery drain mjkiefer General Saturn Discussion 22 01-04-2019 05:59 PM
Battery Brain: product to prevent battery drain davesaturn Ion Tech 19 04-13-2008 08:19 PM
Drain on battery? meseville S-Series Tech 6 04-09-2008 09:59 PM
Campaign for battery drain mcvue 2008 Vue 18 02-26-2008 09:51 AM
Battery Drain -- Ignition?? JoshM20 S-Series Tech 6 10-29-2007 09:16 PM
