Go Back   SaturnFans.com Forums > Models > Saturn Sky > Sky Tech
Old 03-17-2009, 09:52 AM   #1
skyrn
skyrn is on a distinguished road
Default How do you reset psi after dead battery
My saturn sky redline wouldnt start after the weekend of sitting in the garage. After jumpstarting it, the Warning light is on that my PSI is low for the tires. When I press info to look at them, they are all reset to 0. I figured after driving a little while it would reconfigure but it never did. How do I reset my PSI and get the warning lights off????
Add to skyrn's Reputation
Rate the quality of this post and help skyrn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
skyrn is offline   Reply With Quote
Old 03-17-2009, 10:24 AM   #2
webbkarz
webbkarz is on a distinguished road
Default Re: How do you reset psi after dead battery
Turn ignition on, hold lock and unlock buttons on fob until you hear a double-beep from your horn. Starting with the left front tire release pressure until you hear the horn beep, then do the same with the r.f then r.r then l.r.. You should hear a double-beep from the horn after the l.r. tire is done. Turn off the ignition, set the tire pressures to spec then go drive it. Should be all good unless you have a bad sensor or rcdlr(remote control door lock receiver).
All this should be covered in your owners manual.
Del
'95 SC2
'93 BMW 325is
Tulsa, OK
Add to webbkarz's Reputation
Rate the quality of this post and help webbkarz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
webbkarz is offline   Reply With Quote
Old 03-17-2009, 12:42 PM   #3
skyrn
Completely air out the tires?.... seems like there would be an easier way!
Old 03-17-2009, 12:53 PM   #4
haunter
haunter is on a distinguished road
2008 Astra XR
I believe they just have to lose 5 or so PSI till they are below the warning threshold, then it will honk.
Add to haunter's Reputation
Rate the quality of this post and help haunter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
haunter is offline   Reply With Quote
dead battery? kevo420 S-Series Tech 9 03-12-2008 06:47 AM
Dead Battery steveluvs3 Aura General 76 02-25-2008 01:27 PM
SL 94 - battery dead Pega_de S-Series Tech 7 04-24-2007 02:29 PM
Battery keeps going dead 1993_SL2driver S-Series Tech 3 04-19-2007 10:31 PM
Dead battery Danno S-Series Tech 1 09-03-2000 09:07 PM
