Old 12-07-2012, 10:35 PM   #1
prioris
prioris is on a distinguished road
Default sounds like the timing chain coming in contact with timing cover
i have 1999 saturn sl1 220K miles
i am going to have my timing chain replaced. the part i sent away for will be here next wednesday so probably have it changed latter part of next week.
when i listen to the timing cover, there is a clack clack clack sound.
it does kind of sounds like the timing chain coming in contact with timing cover or maybe loose chain but wouldn't really know.
last week one guy who has lots of experience with cars said that i need to get timing chain replaced but as long as the car isn't driven rough, it should be ok for a while
someone else is driving the car and they need it to get to work so will probably put another 150 miles or so on it before it can get fixed.
my main concern is that the saturn is an interference engine and that if it breaks, it could be costly.
Add to prioris's Reputation
Rate the quality of this post and help prioris reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
prioris is offline   Reply With Quote
Old 12-07-2012, 11:22 PM   #2
Default Re: sounds like the timing chain coming in contact with timing cover
If the chain is actually hitting the block you are making aluminum chunks inside the engine, not good. Take the belt off and see if it still makes the same noise. Do this with a cold engine.
Old 12-07-2012, 11:57 PM   #3
prioris
i probably don't have the tools to do that but if i can get my hands on some, what will it tell me besides it not being the belt.
the noise is at its worst when idling but gets quieter when the car gets driven
Old 12-08-2012, 01:12 AM   #4
The problem is most likely the BELT tensioner and not the timing chain.
You need a 14 or 15 mm box end wrench.
http://www.youtube.com/watch?v=BdhCzA0NcDQ
timing chain sounds like it could be coming into contact with timing cover prioris Sky Tech 0 12-07-2012 10:31 PM
timing cover still not coming out RobertGary1 S-Series Tech 18 06-11-2011 12:45 PM
Engine making noise sounds like a knock some say it can be timing chain Gyva S-Series General 5 05-06-2006 10:23 PM
saturn 2000 Timing chain contact me Holly L-Series General 20 05-24-2005 08:04 PM
Behind the timing chain cover My95Sat S-Series Tech 19 12-18-2004 01:48 PM
