Old 05-30-2012, 06:08 PM   #1
tchida14
tchida14 is on a distinguished road
2000 SL2
Default Apexi V-ACF2
Is one of these a good idea to install if your looking to get better cams?
Add to tchida14's Reputation
Rate the quality of this post and help tchida14 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tchida14 is offline   Reply With Quote
Old 05-30-2012, 07:09 PM   #2
fetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nice
1996 SC2
1997 SW2
Default Re: Apexi V-ACF2
It'd be a great idea if you had a car it'd actually work on... http://www.nengun.com/apexi/v-afc-ii
SAFC I or II is the cheapest idea, though it only works at full (higher then ~80%) throttle.
Megasquirt is the best "cheap" option.
My collection of S-Series info: "https://drive.google.com/folderview?id=0B5D8XfJgavxrdE5mcHBlMG5rbUU&usp=sharing" (copy & paste between quotes)
Old 05-31-2012, 10:37 AM   #3
PlasticCarsRock
PlasticCarsRock's Avatar
1995 SL2
SAFCII + wide band O2 sensor is all you need for a mild build. A MSII may allow you to smooth out the rough idle a bit by messing with the fuel/timing curves at idle, but it's a lot more work, and unless you really know what you're doing, it's very easy to blow something up. Unless you're running an extreme build or high octane fuel (> 93) you aren't likely to see any significant benefits from spark control at WOT--the stock ignition timing will advance as far as is safe, in most cases.
Other than correcting for "cam lope" at idle, there typically isn't much tuning that needs to be done below 80% throttle.
Note: if you have really aggressive (custom) cams, you may need ignition and fuel control at idle just to make it run. What cams/specs are you looking at?
High compression build: .033" shaved/ported head, flat-faced valves; gen3 rods, pistons, tie-plate; OE header, custom CAI, SDA street cams with adjustable sprockets, WBO2, SAFCII, LSD. ASE A1-A8+L1
Add to PlasticCarsRock's Reputation
Rate the quality of this post and help PlasticCarsRock reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-05-2012, 11:07 AM   #4
tchida14
2000 SL2
thank you guys. i'm not really looking to buy anything, i'm just dreaming and was just wondering haha
I got my apexi in! MidWest SC2 S-Series Mods 15 05-02-2007 10:40 PM
apexi s-afc jonsq54 Vue Mods 1 03-21-2007 07:07 PM
Apexi BOV jentzsch23 Ion Mods 8 01-21-2007 03:48 PM
Apexi AFC neo YIN Vue Mods 7 10-03-2006 05:09 PM
APEXi grinnen30 Mods and Performance 4 01-10-2002 11:07 PM
