Old 02-03-2017, 07:46 PM   #1
matt95
matt95 is on a distinguished road
Default Haywire turn signal 2003 vue
Hopefully this is the right place to post, so here goes.
Around Christmas I hit a small doe on the driver side. No damages to the car in terms of physical dents or anything like that. After I get home I noticed my right blinker would blink fast. Bad bulb I thought. I also noticed my fogs would only sometimes work. Sometimes it would be one or both.So I come back out in the morning and everything works fine. It would work and not work for about 2 weeks before it quit working. With no seemingly corolation to anything.
After that the right blinker is bad again. It blinks but is so dull it can hardly be seen. And my driver side fog does not work. I switched blinker bulbs and it has no effect on it. So the bulbs are good. The connection has no signs of corrosion either.
Have seen people mention trying the hazards. The right turn signal is weak. Again can hardly been seen, all others are good. I have not torn into the fog light issue but I'm a little confused were to start with these problems.
So what is everyones option on where to look or start? Any input would be greatly appreciated, thanks!
Add to matt95's Reputation
Rate the quality of this post and help matt95 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
matt95 is offline   Reply With Quote
Old 02-04-2017, 10:05 AM   #2
billysvue
Default Re: Haywire turn signal 2003 vue
Originally Posted by matt95 View Post
No damages to the car in terms of physical dents or anything like that. After I get home I noticed my right blinker would blink fast. !
REmove your R/blinker and plug it in to your good side( left) to test and move your L/ blink to the right side.
Does the problem move with the blinker or stay put?
There must be some damage that's noticeable with the removal of the blink assy...
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 02-04-2017, 10:55 AM   #3
far2grumpy
far2grumpy's Avatar
Matt ... see thumbnail ... there's a splice point (SP101) and ground point (G101) attached to frame behind the left front headlamp.
All front turn/hazard signal and fog lamp ground wires (black) are routed to SP101/G101 so there's a good chance one or more wires were damaged by the collision.
The easy way out would be to go to non-performing light fixtures to strip a small piece of insulation from black wires and connect pieces of new wire (make joint waterproof) and route other end of new wire to a nice clean ground point.
This should put you back in business.
Old 02-04-2017, 12:59 PM   #4
matt95
I put the bulb that worked in the right side and it did not work. I'll be trying a few other things and report back.
Old 04-07-2017, 12:12 AM   #5
drowsytaco
drowsytaco is on a distinguished road
2003 VUE 2.2L
Idea Re: Haywire turn signal 2003 vue
I had my turn signals go haywire and it was caused by my Emergency lights button, after pressing it a few times and seemingly getting it in the right spot, my blinkers worked again. Doesn't give me any problems unless i mess with it
Add to drowsytaco's Reputation
Rate the quality of this post and help drowsytaco reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
drowsytaco is offline   Reply With Quote
2003 Vue Turn Signal Switch Issues njgliderider 2008 Vue 0 09-28-2014 09:59 PM
2003 Saturn Vue AC and Turn Signal Problems HELP!!! 1gtp11 Vue General 2 07-25-2012 08:46 PM
2003 Vue Turn signal cancel problems majacoby Vue Tech 0 04-01-2007 08:40 PM
2003 Ion Turn Signal Problem dewermcd Ion General 2 04-01-2007 02:36 PM
2003 Ion turn signal RICH Ion General 16 07-29-2004 01:26 AM
