Old 10-21-2011, 08:03 PM   #1
MattBarszcz
MattBarszcz is on a distinguished road
MattBarszcz's Avatar
2002 SL1
Default Anyone have an extra power steering bolt?
I need 1 8mm 1.25 x40mm power steering bolt. One of mine has the head sheared off. I don't have a scrap yard anywhere near where I live and I don't know where else to get one. Anyone have one they could send me? I'll give you a couple bucks for it if you want.
Please help
--Matt
Add to MattBarszcz's Reputation
Rate the quality of this post and help MattBarszcz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MattBarszcz is offline   Reply With Quote
Old 10-21-2011, 08:05 PM   #2
MattBarszcz
2002 SL1
Default Re: Anyone have an extra power steering bolt?
Also, how hard is it to attach the reservoir to a new power steering pump that doesn't come with one?
Old 10-21-2011, 08:48 PM   #3
dorisSL
dorisSL is on a distinguished road
dorisSL's Avatar
1995 SL
have you tried ace/true value/do it best?
a good hardware store will have a good selection of....hardware
and usually, if not, they'll know where you can get a better selection of fasteners. you're a step ahead of most customers by knowing size, pitch and length.
1995 SL, born 12/23/94, manual, WAI 190,500, "Doris"
(I'm Ben, the car is Doris)
you can't mulch at those speeds man, that's too fast
Add to dorisSL's Reputation
Rate the quality of this post and help dorisSL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dorisSL is offline   Reply With Quote
Old 10-21-2011, 10:08 PM   #4
MattBarszcz
2002 SL1
I could probably get a regular bolt at a hardware store, but it wouldn't have the same head (also it wouldn't have that black coating on it like the one that was in there) as the one that came out (with a sort of washer shaped head). Would that matter?
Old 10-22-2011, 01:44 AM   #5
dorisSL
dorisSL's Avatar
1995 SL
sounds like a flange bolt.
the big difference is the shape, which can be replicated with a bolt and a washer, but flange bolts are also often i higher grade of steel (12.4 instead of 10.2)
the Ace i used to work at carried them, but not all do.
check your phonebook/google for local fastener stores. around here we have a chain called Tacoma screw. they carry/can get basically any fastener under the sun. i bet there's someone like that around you even if your hardware store doesn't have what you're looking for.
Old 10-22-2011, 02:48 PM   #6
MattBarszcz
2002 SL1
Thanks dorisSL, flange bolt, that was the key. Much easier to find when you know what they're called. My local Advanced had them. They were in a pack of 4 - M8-1.25x40mm. Class 10.9 so they are actually stronger than the originals.
Thanks,
matt
Hidden Extra 12V Power Outlet Install w/ Pics tenn734 S-Series Mods 21 06-18-2014 09:59 AM
Extra Power? mickyads92 Vue Mods 1 04-27-2011 12:49 AM
where did that extra power come from? tmhd2 Ion General 12 12-05-2005 01:47 PM
power steering leak/steering rack question Gadweller S-Series Tech 9 11-19-2005 02:18 PM
Need a little extra power, especially with A/C on 98greenSC2 S-Series Mods 10 03-06-2004 12:07 PM
