Old 03-18-2012, 12:37 AM   #1
dorisSL
dorisSL is on a distinguished road
dorisSL's Avatar
1995 SL
Default doris' coolant issues continue
several months ago, Doris finally got the inevitable leaky radiator, so i replaced it with the recommended one (it was clearly a gm part with the gm logo scratched off)
after replacing it, i checked the coolant every day for a few days to make sure it was still full, and i never had to top it up.
two or three days ago, my low coolant light started blinking when on steep hills, so i checked it today and it was low, so i topped it up (took about a 1/2 cup). poked around the engine bay for any signs of a leak, didn't see any.
i do have a little bit of black in the coolant reservoir (the coolant looks normal, this is like a thin layer on the inside of the tank itself). i also noticed some orange buildup where the top radiator hose meets the engine block. no signs of leaks anywhere, though, unless it's a another hairline crack somewhere.
so, i'm hoping it's not a head gasket leak or cracked head, but i'm not sure how to test for either, and i'm wondering if there's anything else it might be.
also, if it is a leaking gasket, how long can i nurse it before it dies? time/money will likely be tight until mid-may, when i might be able to take time off work and catch up on finances.
also, any ballpark figures for an average head gasked replacement?
1995 SL, born 12/23/94, manual, WAI 190,500, "Doris"
(I'm Ben, the car is Doris)
you can't mulch at those speeds man, that's too fast
Add to dorisSL's Reputation
Rate the quality of this post and help dorisSL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dorisSL is offline   Reply With Quote
Old 03-18-2012, 01:02 AM   #2
Default Re: doris' coolant issues continue
Shop cost to do a head gasket is high. Th e orange goo around th e hose is your leak and the bathtub ring is the original dose of walnut hulls. Wipe your finger in it and it will be slightly gritty. Replace hose or tighten clamp.
Old 03-18-2012, 11:57 PM   #3
Signmaster
I'd second that as the leak spot. Probably coming out as mostly steam, and the heat is steaming any droplets off before they can be spotted.
My lower hose lost a tiny amount after the radiator change, and the car had to be up to near fan on temp to even see the steam mist.
a/c and coolant issues....need help a_brooks86 S-Series Tech 22 09-16-2009 01:30 AM
Making doris legal... dorisSL S-Series Tech 26 07-02-2009 03:54 PM
Radio Issues Continue To Anger Me.... QKSC2 S-Series Tech 19 06-17-2008 10:37 AM
Poor Gas Mileage, Exhaust Issues Continue cjhsa Vue General 21 02-25-2007 01:05 PM
Coolant Gauge Issues saturnrings S-Series Tech 1 10-10-2002 01:25 AM
