Old 09-24-2013, 08:38 PM   #1
SteveTJ
SteveTJ will become famous soon enoughSteveTJ will become famous soon enough
Dizzy No Coolant level / transmission temp TellTale light
1998 SL2 Wrench light on codes 1640 and 1641 .
Telltale light for Coolant Level/transmission temp... Does NOT come on when I turn the ignition on. Only the WRENCH when running (25-40 sec after starting).
Has anyone ever seen this before?
I checked and got voltage at instrument cluster connector(Drk Green wire) disconnected battery and sent 9v (using 9v battery) + to connector with - side grounded. TellTale bulb lit up. Checked wire with ign off and got resistance.
High ground side resistance during bulb check or engine running.
If anyone has any ideas what else I can check before I blame the PCM?
Thanks
SteveTJ
Add to SteveTJ's Reputation
Rate the quality of this post and help SteveTJ reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SteveTJ is offline   Reply With Quote
Old 09-24-2013, 10:03 PM   #2
adventureoflink
adventureoflink's Avatar
Default Re: No Coolant level / transmission temp TellTale light
maybe the float is disconnected or the wires/connection are bungled?
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Add to adventureoflink's Reputation
Rate the quality of this post and help adventureoflink reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-25-2013, 12:26 PM   #3
SteveTJ
I checked the coolant level sensor. Check connector 14v across the connector. Open connector engine running - no light. Shorted connector engine running - no light. Also checked engine fan comes on with A/C on, so fan relay works.
Old 09-25-2013, 04:22 PM   #4
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Are you sure about that? I'm not trying to be a smarty pants, but engine sensors use a 5-volt reference signal (oxygen sensors are the exception).
2007 Ion 2 Quad Coupe 5-speed manual 181K miles
2007 Chevy Equinox LT 193K miles
2018 Chrysler Pacifica Touring L 36K miles
Add to ruley73's Reputation
Old 09-26-2013, 08:41 AM   #5
SteveTJ
Problem Solved
Broken wire between PCM and dash.
Yes it did measure 14 Volts at the Water Coolant level connector. I also thought it would be 5V. Maybe it had something to do with the broken PCM wire being broken.
Old 09-25-2013, 01:26 PM   #6
Sounds like a bulb failure.
Old 09-25-2013, 06:37 PM   #7
SteveTJ
Problem Solved
I figured while I had the top of the dash off I would check the PCM connectors. Pulled out the PCM and saw that one of the wires was just hanging. Found the other end under the dash and soldered it back together. No more wrench light and teltale for coolant level lights when ignition is first turned on.
Stevetj
Old 09-25-2013, 06:58 PM   #8
Well, that is an unusual failure.
Old 09-25-2013, 07:37 PM   #9
madpogue
1996 SW2
This just happened out of the blue? Something must've cut/broken that wire.
Add to madpogue's Reputation
'98 SC2 - High Engine Coolant Temp and Low Coolant Level Warning Light mystic54 S-Series Tech 3 01-17-2013 09:29 PM
Temp/Coolant Level Idiot Light Question ReelCrazy1 S-Series Tech 4 07-05-2008 05:35 PM
Coolant Temp & Level Light Flashing NJ-SL S-Series General 7 04-09-2004 07:56 PM
Intermitant coolant temp. and coolant level light? speedy45 Miscellaneous Tech 1 11-01-2001 08:40 PM
Coolant Temp/Level light flashing Rodney S-Series Tech 8 03-30-2001 02:21 AM
