Old 05-01-2002, 10:48 PM   #1
darren y
darren y is on a distinguished road
darren y's Avatar
Default Accessing DLC codes on a 97 SC2
I've got an 97 SC2 with a recurrent check engine light. we haven't been able to track it down yet, in my manual it says how to check the engine codes for a 91-95 saturn but makes no reference on how to check the codes on my 97.
Are the scanners for this available/affordable or is there a trick way to access the codes with a jumper wire like with the ALDL systems??
Any help or advice would be greatly apprciated.
Thanks, Darren
Add to darren y's Reputation
Rate the quality of this post and help darren y reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
darren y is offline
Old 05-02-2002, 09:53 AM   #2
eRic 02sc2
eRic 02sc2's Avatar
Default
on 96 and later (OBD-II) you can't do the jumper wire trick. you will need a code scanner. check out http://www.obd2.com/ and http://www.obdii.com/
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Accessing/cleaning the evaporator? 92SC2 S-Series Tech 18 05-27-2009 09:58 AM
Accessing the spare tire Jopo528 Vue General 4 02-04-2008 11:42 AM
accessing your spare tire gel85 2008 Vue 6 01-15-2008 05:02 PM
Accessing aux input on 2000 SC2 OhAySis S-Series General 4 01-11-2006 06:52 PM
1997 SL2 DLC pinout jkaSL2 S-Series Tech 1 12-13-2005 07:27 PM
