Old 05-03-2015, 02:25 PM   #1
Recycled Saturn
Recycled Saturn has a spectacular aura aboutRecycled Saturn has a spectacular aura aboutRecycled Saturn has a spectacular aura about
Recycled Saturn's Avatar
Default Hard to get into gear while engine running
Car is a 1998 SL2. Clutch replaced ~30000 miles ago. I replaced the clutch hydraulic system today thinking that was my problem but that made no change.
Last Thursday my car started becoming hard to get into gear, and now it takes a large amount of force to get it into gear regardless of whether I am moving or stopped. If I am at idle and it wont shift, I can simply turn the engine off and it will go into gear no problem. It is also hard to get out of gear occasionally. Shift cables and bushing look good, tranny fluid is full. No visible leaks of anything
What do the experts think? What is causing this?
1998 SL2-AMR Strut Bar, AEM CAI, and 119,XXX
Add to Recycled Saturn's Reputation
Rate the quality of this post and help Recycled Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Recycled Saturn is offline   Reply With Quote
Old 05-03-2015, 02:42 PM   #2
Default Re: Hard to get into gear while engine running
THE CLUTCH. Run this stroke test to verify teh hydraulics are working properly.
Clutch Wire Test
http://www.saturnfans.com/forums/sho...ight=wire+test
How it works
http://www.saturnfans.com/forums/sho...d.php?t=183128
Old 05-03-2015, 02:46 PM   #3
Recycled Saturn
Another note. If I rev the engine to ~2500 it shifts into gear easily
Old 05-03-2015, 02:52 PM   #4
Sounds like the clutch is not releasing, run wire test.
Old 05-03-2015, 02:54 PM   #5
Recycled Saturn
Clutch Wire Test
How it works
The clutch would fail that rapidly? We are talking in 4 days it went from shifting smoothly to taking a lot of force. Clutch passed the test where you slowly let it out and see if it dies or not and clutch disengages close to the floor
Old 05-03-2015, 03:02 PM   #6
Recycled Saturn
Will do!
Old 05-03-2015, 07:03 PM   #7
Recycled Saturn
I get about .5" with the engine off. Do I need to test it with the engine running?
Old 05-03-2015, 07:31 PM   #8
Is that .5 and a bit more or a bit less. The 0.5 is more than adequate to disengage the clutch.
As was suggested in another thread check the crank end float. Do this with the engine off. You push in and pull out on the crank pulley, it should not be sliding back and forth. It has to be real worn to keep the clutch from releasing so the push-pull test will be fine.
Old 05-03-2015, 08:02 PM   #9
Recycled Saturn
Slightly more than 0.5". I will try that crank test, otherwise it looks like this weekend I will pull the motor and tranny. This will be the 7th time we've done an engine removal, I should be able to do it in my sleep soon
Old 05-03-2015, 08:13 PM   #10
Recycled Saturn
The crank pulley checks out just fine. I'm looking at ordering the luk clutch and pressure plate. Do you recommend I change the flywheel? If so what brand?
Old 05-03-2015, 09:01 PM   #11
There are several options but all of them are OK. This is what I installed and it has held up well, http://www.ebay.com/itm/FX-STAGE-2-C...item5d4adb1e9b Usually sells for 175-180 on best offer. The thing to look for when you open it up is a dull red colored gook inside the bell housing. Black is OK but red is a leaking input shaft seal assembly and that leak will ruin the clutch. A genuine 04-115 LUK and flywheel will cost about the same so it is just a matter if you want a stronger clutch.
Old 05-09-2015, 06:14 PM   #12
Recycled Saturn
Everything back together now clutch pedal won't push. It is stuck in the up position. Thoughts?
Old 05-09-2015, 09:46 PM   #13
Best guess you missed the divot in the arm and the slave is fully extended, do not stomp on it as it will just produce more parts to pick out of the bell housing.
Remove slave cylinder and investigate.
Old 05-09-2015, 11:42 PM   #14
Recycled Saturn
I think you were right. I went to pull out the slave rod hooked on something and fell into the transmission. We pulled it back out and could not find anything wrong. It shifts fine now 95% of the time, the other 5% it seems slightly hard but it my be me accidentally not pushing the clutch in far enough. This new clutch basically engages barely above the floor
Old 05-10-2015, 12:18 AM   #15
Low pedal is normal until broken in, which may take some time.
Old 05-13-2015, 09:50 AM   #16
Recycled Saturn
Just so everyone knows what the problem was:
The clutch was fine but the teeth on the end of the pressure plate were extremely worn and worn unevenly
Old 05-13-2015, 11:41 AM   #17
You can not recycle pressure plates either.
Old 06-19-2015, 06:40 AM   #18
ajs_saturn
ajs_saturn will become famous soon enoughajs_saturn will become famous soon enough
ajs_saturn's Avatar
2001 SC1
I'm having this same issue that started today. I'll be running these tests I suppose. It's annoying because I installed a brand new LUK clutch only 1000 miles ago...
2001 SL1 5spd - DOHC swap and MS in the works
Bought 02/27/14
2000 SL 5spd
Bought 04/05/05
Sold 06/14/10
Add to ajs_saturn's Reputation
Rate the quality of this post and help ajs_saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ajs_saturn is offline   Reply With Quote
Old 06-19-2015, 07:48 AM   #19
Check the fluid level in the clutch master cylinder.
Old 06-20-2015, 03:52 PM   #20
ajs_saturn
ajs_saturn's Avatar
2001 SC1
I check my fluid, it's full. I tried pumping the clutch a few times then shift, no change. I tried holding the clutch in while in 1st gear, car creeps forward immediately. I did the wire test, I have 0.5" of movement, so all 3 tests show my problem is not the hydraulics.
I noticed yesterday that for a few miles of driving, everything shifted normally, then it started acting up again.
This is a new LUK clutch I installed 1000 miles ago. I don't hear about these going bad that soon. I've installed a few clutches in my time with s-series. I used an alignment tool and torqued the pressure plate to flywheel at 19ft lbs with a bit of red loctite on the ends. TO bearing, fork, and retainer are always easy to install. Can't really put that in backwards. Any ideas?
Bought 02/27/14
2000 SL 5spd
Bought 04/05/05
Sold 06/14/10
Sometimes its hard for me to get into first gear. turbobuick33 S-Series General 52 12-10-2015 01:13 PM
06 Ion coupe wont go into gear when engine is running cummins96 Ion Tech 8 03-20-2013 11:01 PM
Will not go into 1st gear when running engine Woody S-Series General 3 05-28-2010 07:12 AM
Will not go into 1st gear when running engine Woody S-Series General 4 05-27-2010 03:59 PM
Reverse gear; Hard to put in gear. loba Astra General 10 03-02-2010 09:21 PM
