Go Back   SaturnFans.com Forums > Categories > General Saturn Discussion
Old 03-25-2003, 11:09 AM   #1
Alchik
Alchik is on a distinguished road
Dizzy Suddenly running rough and hard starting
Hi,
My wife's 92 SL2 suddenly became hard to start. It sounds like it's not getting gas, spark or something. It turns over fine so the battery is good. It's sporadic right now. Sometimes it starts just fine. Also, after this hard start it coughs and sounds like it's going to die for a bit then it revs up like the choke is stuck. When you drive it after one of these starts it downshifts (automatic) hard when stopping with high revs. It has about 135,000miles on it.
At first I thought it may be the PCM but after reading a few threads I read where EGR valves on this model could be the culprit.
Any thoughts, ideas or suggestions would be greatly appreciated! I'd hate to pay an arm and a leg to get it fixed just to find out it was a part that cost less that $50 that I could replace myself.
Thanks,
Alchik
Add to Alchik's Reputation
Rate the quality of this post and help Alchik reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Alchik is offline
Old 03-25-2003, 11:27 AM   #2
Qlara
Qlara's Avatar
Default
I'd suggest you get a new set of spark wires.
If plugs are not replaced yet, do it too.
Add to Qlara's Reputation
Qlara is offline
Old 03-25-2003, 11:48 AM   #3
brentg
brentg is on a distinguished road
Default
check the fuel pressure regulator. is it spitting gas out of the vacuum line?
Add to brentg's Reputation
Rate the quality of this post and help brentg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
brentg is offline
Old 04-02-2003, 03:27 PM   #4
Alchik
Default
Turns out it was the Coolant Temperature Sensor. Once it was replaced it started running smoothly again. Hmm, I never would have thought that....
Thanks for the suggestions (I did check those!)!
Alchik is offline
1992 SL1 not starting/stopped suddenly amrjohal S-Series Tech 4 05-02-2008 09:55 AM
95 SW2 Suddenly running rough lemonhead S-Series Tech 2 09-10-2006 12:01 PM
Suddenly hard to shift into gear 85_SS S-Series Tech 2 06-01-2006 07:42 AM
95 SL1 suddenly running rough Av8r S-Series Tech 6 02-01-2005 03:38 PM
Hard - rough starting ION Ion General 3 06-01-2003 03:23 PM
