Old 01-10-2006, 09:23 PM   #1
92xjmuddin
92xjmuddin is on a distinguished road
Default Blower Motor Resistor
I am having trouble finding the blower motor resistor. A mechanic told me that it was under the dash, and that i would have to remove the glovebox to get to it, i removed a few screws and took a peek but i still dont see it. Is this the correct location?
Add to 92xjmuddin's Reputation
Rate the quality of this post and help 92xjmuddin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
92xjmuddin is offline   Reply With Quote
Old 01-11-2006, 07:10 PM   #2
bigc791
bigc791 is on a distinguished road
bigc791's Avatar
1994 SL1
Default Re: Blower Motor Resistor
You have to stand on your head to see it. Its on the bottom of the hvac case. No need to remove the glove box. Also its reccomended to replace the blower motor too at the same time to prevent the new resistor from burning up
Carmen
1998 2.4L swapped Plymouth neon is my ride.
Add to bigc791's Reputation
Rate the quality of this post and help bigc791 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigc791 is offline   Reply With Quote
Old 01-12-2006, 08:01 AM   #3
92xjmuddin
Thanks for the reply. I am comming from the Jeep world, this is my moms car, can you give a description of where the HVAC case is located? And also which side of the car it is most easily accessed from.
Old 01-12-2006, 10:58 PM   #4
lostwages_ls2
lostwages_ls2 is on a distinguished road
lostwages_ls2's Avatar
2000 Saturn LS2 V6-3.0L VIN R
Top - Vehicle
Heating and Air Conditioning
. Blower Motor Resistor
. . Service and Repair
Notes
Service and Repair
BLOWER MOTOR RESISTOR
REMOVAL
Disconnect negative battery cable.
Open glove box door.
Remove glove box lamp assembly by pulling on lamp plunger.
Disconnect glove box lamp wiring harness from glove box lamp.
Remove right side I/P lower dash insulator retainers.
Pull insulator rearward to detach from forward insulator retainers.
Remove right side heater outlet assembly retainer and remove outlet.
Remove glove box door.
Remove glove box bin fasteners.
Slowly remove glove box bin tilting bin downward to expose the BCM module residing on top of the glove box.
Remove BCM module from glove box by sliding module out of attaching slots.
Remove glove box bin.
Disconnect recirculation actuator electrical connector.
Remove blower motor resistor screws.
Use electrical harness to pull resistor card out of module.
Disconnect blower resistor card from electrical connector.
INSTALLATION
Connect blower motor resistor electrical connector to resistor card.
Install blower resistor card into slot in module with circuit side facing towards rear of vehicle. It will only fit one way.
Install blower motor resistor screws. Torque: 1 N.m (9 in-lbs)
Connect recirculation actuator electrical connector.
Install glove box bin partially into opening.
Secure BCM module to glove box bin slots.
Route glove box lamp wiring harness through lamp opening.
Install glove box bin to I/P with fasteners.
Connect glove box lamp wiring harness to glove box lamp.
Snap lamp into glove box bin.
Install beater outlet with retainer.
Install lower dash insulator with retainers.
Function glove box lamp and glove box door to ensure proper operation.
Install glove box door with fasteners. Torque: 2 N.m (18 in-lbs)
Connect negative battery cable. Torque: 17 N.m (151 in-lbs)
Copyright 2006 ALLDATA LLC
Terms of Use
Your Honor Student is merely a pawn in my Min Pin's diabolical world domination plot.
Obey the Min Pin
Add to lostwages_ls2's Reputation
Rate the quality of this post and help lostwages_ls2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lostwages_ls2 is offline   Reply With Quote
Old 01-13-2006, 08:39 AM   #5
92xjmuddin
OK *bangs head through a wall*
The blower motor is good. The fuse is good. I just changed the resistor. What else can it be? There is no air blowing at all.
Blower Motor Resistor? UsNsUbSoNaR S-Series Tech 26 02-04-2019 10:30 PM
blower motor resistor? where is it blower23 S-Series Tech 4 05-17-2009 01:26 AM
Where can I get a blower motor resistor? hd071502 Vue Tech 5 07-02-2008 09:40 PM
LS-1 blower motor and resistor block tgermann1962 L-Series Tech 0 08-23-2007 01:46 PM
Blower resistor motor IrishDMBF Ion General 3 08-08-2007 12:12 AM
