Old 09-18-2023, 02:35 PM   #1
ckrobins
ckrobins is on a distinguished road
1997 SW1
Question What is this thing?
I've replaced the engine in my 2000 Saturn LS1, and I'm working through the wiring harness(es) in the engine compartment. I have been unable to identify the item circled in orange in the attached picture. I have both of the L-Series shop manuals (Body/Electrical I and II) and a Chiltons manual to refer to, but have had no luck. If you can identify this part and it's connection point, would you please reply to this post? Thanks!
ckrobins is offline   Reply With Quote
Old 09-18-2023, 10:16 PM   #2
02 LW300
02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold
02 LW300's Avatar
2002 L-Series 3.0L Wagon
Default Re: What is this thing?
That is a ground splice.
2002 LW 300 loaded, just rolled 100,000 miles, new timing belt and goodies
2002 L200/5 Loaded, 280k grandson’s car
2000 LS1, TMU love those bcm failures., grand daughter’s car
Old 09-18-2023, 10:22 PM   #3
02 LW300
02 LW300's Avatar
It mounts under the front side of the battery tray, directly below the battery hold down. The battery hold down holds the fan relay box. There is a stud welded to the inner fender.
Old 09-20-2023, 04:00 PM   #4
ckrobins
1997 SW1
Thanks, 02 LW300, that was useful information. After a little more study of the Saturn's body/electrical manuals, I found it in the schematics - it is called 'forward lamp splice pack' in the ground distribution schematics. I did not find a stud in the location you mentioned, but a little sandpaper, a star washer and a beefy sheet metal screw later that is where it is. The negative ground post of the battery is fastened to the inner fender about a foot farther back on the inner fender, so I am confident that the splice is grounded.
I attached another copy of the picture I initially posted with a wire/terminal circled in green.
I checked continuity from this terminal to the negative battery terminal and it is connected. So, I think this means that the terminal is meant to attach to another underhood component to supply a ground. (I don't think the physical position it's in is correct) It emerges from the wire harness where the positive and negative battery cables do, and it is long enough to reach the engine block, cylinder head, or transaxle. Do you know where it goes?
Old 09-21-2023, 12:29 AM   #5
02 LW300
02 LW300's Avatar
I suspect that it is another body ground. The main ground cable bolts to the engine. They tie all the grounds together through various cables and wires. As long as it is black it is a ground.
If it's not one thing, it's another. spacetrace33 S-Series Tech 2 08-10-2015 05:21 PM
What's the next best thing to 5W-30 Oil? coolgreany S-Series Tech 6 10-26-2008 11:00 PM
what is this thing jonsq54 Vue Mods 1 05-02-2007 04:36 AM
Hey man, has that thing got a H...... Bill Murray Vue General 3 03-03-2004 07:05 PM
not one thing its another Saturn94buff Miscellaneous Tech 6 12-07-2002 09:02 AM
