Old 07-27-2023, 11:52 PM   #1
rjc862003
rjc862003 is a jewel in the roughrjc862003 is a jewel in the roughrjc862003 is a jewel in the roughrjc862003 is a jewel in the rough
Default Rear trailing arm bushing replacement?
anybody know any hacks to replace the rear trailing arm bushings without taking the brackets off ? I really don't want to open the can of worms that is unbolting the axel and dealing with cage nuts
I thought about maby if you removed both shocks and springs and hung the axel with ratchet strap you might get enough clearence to get em out of there
rjc862003 is offline   Reply With Quote
Old 08-01-2023, 09:35 PM   #2
Bill Murray
2007 ION-2 Quad Coupe
1997 SC1
Default Re: Rear trailing arm bushing replacement?
If you read the comments section under this YT vid, there's a lengthy comment where a fellow talks about successfully doing exactly what you propose. He did have to fabricate some tooling to press the bushings. Good luck!
https://www.youtube.com/watch?v=D0VDc7herrk
This video removes the brackets but still has some useful info (Chevy HHR but I think same parts, Delta platform)
https://www.youtube.com/watch?v=ThMeUIZSCGY
Trailing arm bushing Tyson L-Series Tech 4 10-02-2019 04:43 PM
2008 saturn vue rear trailing arm bushing MOOG dabatman99 Vue General 2 11-16-2015 06:37 PM
trailing arm bushing fetchitfido S-Series Tech 1 04-05-2013 01:16 PM
trailing arm bushing 04 AWD rowdydog Vue Tech 2 11-01-2012 09:16 AM
Rear trailing arm bushing shot.. any replacement? chaisedetivieux Vue General 2 08-19-2012 08:53 PM
