Old 03-25-2014, 12:00 PM   #1
sw201444
sw201444 is on a distinguished road
sw201444's Avatar
1996 SL1
Default Digital CLuster swap..?
Can I put a later model (98-99) cluster in my 96? I want one of the ones that has electronic mileage and such. Mine rattles to hell. And doing some research, was why they went to the electronic. Regardless. I want an electronic one. Can I put one in my car without rewiring everything?
-Did they make white ones of these, too? I don't want to swap the inlays and screw up the needles or whatever.
'96 SL1
INSTAGRAM: sw201444
Add to sw201444's Reputation
Rate the quality of this post and help sw201444 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sw201444 is offline   Reply With Quote
Old 03-25-2014, 12:06 PM   #2
ninetynineSC2
ninetynineSC2 has a spectacular aura aboutninetynineSC2 has a spectacular aura aboutninetynineSC2 has a spectacular aura about
ninetynineSC2's Avatar
1999 SC2
Default Re: Digital CLuster swap..?
The 99 homecomings had white digital gauges as well as the 10th anniversary SL2. Can't help with the main question though.
More reading here
Add to ninetynineSC2's Reputation
Rate the quality of this post and help ninetynineSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ninetynineSC2 is offline   Reply With Quote
Old 03-25-2014, 12:11 PM   #3
The stock white 2nd gen gauge's were on DOHC models, the speedometer and tachometer won't read correctly on a SOHC.
Not sure anyone's actually tried the swap yet to a '96 but it's been verified to work with '97's.
With the digital odometer you'd be stuck with whatever the reading is, unlike the mechanical odometer that takes maybe 10 minutes (and free unless you break something) to change the digital is far more intricate & costly.
Old 03-25-2014, 12:17 PM   #4
ninetynineSC2
1999 SC2
That totally slipped my mind in my post.
Old 03-25-2014, 12:19 PM   #5
sw201444
sw201444's Avatar
1996 SL1
okay, so no white, but my title already reads that my car has odo discrepancy. it reads 157,xxx and has about 228,xxx on it...
I'm just so sick of *raaaaaaaatle* when driving or something, nothing is loose in there but the stupid mileage counters.
'96 SL1
INSTAGRAM: sw201444
Old 03-25-2014, 12:20 PM   #6
trottida
trottida's Avatar
If I recall correctly the switch to digital came mid-year of the 98 model run and the 98 and 99 digital gauge clusters would likely be compatible with the 96. The 99 Homecoming gauge cluster would likely be the only compatible white faced gauge cluster. A Vue or Torrent cluster might work - I can't recall which years they shared the same gauge clusters.
The 2000 and later models stored the mileage in the BCM and are definitely not compatible.
Although, I think you would lose your odometer reading and adopt the donor car mileage if you switched.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 03-25-2014, 12:22 PM   #7
sw201444
sw201444's Avatar
1996 SL1
Read above, i added info in my current mileage.. vue clusters are gen 3, unfortunately..
Also, as stated above, wouldn't the reading be off if it were a DOHC cluster? (which were the only OEM white ones)
'96 SL1
INSTAGRAM: sw201444
Old 03-25-2014, 12:24 PM   #8
trottida
trottida's Avatar
They do in 3rd gen; I run a DOHC 10th Anniversary Edition silver faced gauge cluster in my SOHC. The MPH and RPM readings are correct; the red line markings are not though (4500 vs 5500). Mind you the digital odometer reading is dim but I'm unsure if that is a compatibility issue or a fault in the gauge cluster.
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 03-25-2014, 12:43 PM   #9
Way to confuse the OP with useless information. 3rd gen's use a BCM for the brains for just about everything unlike 1st & 2nd gen, so they have many more swap options than earlier models.
'96-'99 have the potential to swap (DOHC->DOHC and SOHC->SOHC) while only '98/'99 to '97 has been verified to work (that I know of). '95 is unique to '95 for the majority of the electronics, not just the cluster.
Old 03-25-2014, 12:49 PM   #10
sw201444
sw201444's Avatar
1996 SL1
Okay, so I have heard that dohc>single swap will work
I'm not worried about RPM readings because I drive an Autotragic.
Will a dohc gauge work in a single? I have you guys saying yes and no, I also have facebook telling me yes and no.
EDIT: mine's a 96, theoretically identical to 97
'96 SL1
INSTAGRAM: sw201444
Old 03-25-2014, 02:08 PM   #11
trottida
trottida's Avatar
I apologize, those weren't my intentions. My point was that the 2nd Gen DOHC cluster swap into a 2nd Gen SOHC would likely work as it does in a 3rd Gen. I would think that the speed, rpms, fuel and temperature inbound data signals should be the same for both DOHC and SOHC. 2nd Gen behavior would likely be the same but it would have to be experimented with to be conclusive. Has it been attempted? I haven't seen any mention of it over my years here on this forum but maybe I over looked it. I've only owned 1st and 3rd Gen Saturns.
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 03-25-2014, 03:35 PM   #12
sallydriver
sallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to all
sallydriver's Avatar
1993 SW2
Don't know about year compatibilities, but I've heard of people printing out overlays on their home printers, then puting that on the gauges, after cutting out the various warning lights. I don't know where one would obtain the image to print though.
1998 Red SL 5spd "The Right Honorable Duke Farnsworth the Functional of Clearfield":165,000 miles
1999 Forest Green SL2 5spd "Sally": 307,100+ miles
1993 White SW2 5spd "Steve": 234,984 miles
Add to sallydriver's Reputation
Rate the quality of this post and help sallydriver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sallydriver is offline   Reply With Quote
Old 03-25-2014, 03:55 PM   #13
See post 9, here
http://www.saturnfans.com/forums/sho...d.php?t=173765
posts 7 and 10 here, but also 12
http://www.saturnfans.com/forums/sho...d.php?t=191186
No personal experience/opinion
OP did not want to do overlays, but people have posted the files here as well as other places.
Old 03-25-2014, 05:37 PM   #14
sallydriver
1993 SW2
Understood. I merely wanted OP to know there are multiple options for changing the appearance.
Old 03-25-2014, 07:22 PM   #15
sw201444
sw201444's Avatar
1996 SL1
See post 9, here
Those still conflict with eachother
"they do work"
"they don't"
"they do"
'96 SL1
INSTAGRAM: sw201444
Old 03-25-2014, 07:25 PM   #16
sw201444
sw201444's Avatar
1996 SL1
Noted.
Also... ANOTHER FOREST GREEN
woot woot.
'96 SL1
INSTAGRAM: sw201444
Old 03-26-2014, 12:57 PM   #17
Originally Posted by sw201444 View Post
Those still conflict with each other
Exactly I think the only way to know for sure is to try it out yourself. in cases where it worked (or were off a few mph or whatever), we don't know if that's just due to calibration for that particular panel, or maybe someone swapped faces on that panel before the current owner got it.
Though, if you have given up on white-gauge faces, no reason you can't just use a SOHC panel
Personally, I think it will work, but that's just a guess and I don't want to waste your money. Here's a few threads at 6s that says it will work.
http://sixthsphere.com/showthread.ph...DOHC-questions
http://sixthsphere.com/showthread.ph...-****-together
http://sixthsphere.com/showthread.ph...C-to-DOHC-swap
gotcha, was just saying, if the OP changes his mind, the white-face gauge files are around here somewhere
I saved off a copy of some photoshop files of white gauges, though they need to be reworked to get rid of some "extras" that whoever made them added. I can repost or email if desired (largest file is a little over 10mb)
Also saved off theRob's instructions for converting, which is good since theRob's site is gone.
Old 03-26-2014, 10:02 PM   #18
sw201444
sw201444's Avatar
1996 SL1
So my BEST bet would be to get an SOHC cluster.. and put white gauges in?
'96 SL1
INSTAGRAM: sw201444
Old 03-27-2014, 12:25 AM   #19
If you want other than stock looking gauge's, and have a SOHC your ONLY option is getting SOHC overlays.
TheRob's printable overlays are for DOHC's (all the printable overlays I've seen are for the DOHC's), 99% of the mods are for DOHC's. Well, the fuel & coolant temp sections will work fine on the SOHC but otherwise nope.
1997 to 1999 clusters have been confirmed to swap fine, 1996 has not been confirmed as an additional year to the '97-'99 range and 1995 has been confirmed to be unique to 1995.
If you want to keep the mechanical odometer, these will work fine ('95-'97 SOHC): http://www.ebay.com/itm/1995-1996-Sa...-/380872282009
I'm not seeing actual '98-'99 SOHC overlays, just typical eBay idiots mislabeling everything.
Old 03-27-2014, 01:12 AM   #20
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Change the theater (backlights) when you have the dash cluster out....
Mine is now a pretty amber...
http://www.superbrightleds.com/searc...nt-bulbs/pc74/, several color choices and two intensities...
For the other cluster lights, match film color to LED color...
NGK BKR6E-11 spark plugs
Saturn Ion2 Cluster Swap with Redline cluster chanoir Ion Mods 12 02-19-2014 10:16 PM
cluster swap? solarcar_sc1 S-Series Mods 3 03-22-2012 01:18 PM
change milage on a digital cluster marmitage S-Series Tech 14 07-13-2011 01:27 AM
cluster swap??? fishmed S-Series Tech 8 03-12-2008 11:21 PM
Cluster Swap??? chitown616 Vue Tech 5 03-30-2006 06:38 PM
