Old 03-12-2014, 01:28 PM   #1
sw201444
sw201444 is on a distinguished road
sw201444's Avatar
1996 SL1
Default Help! Motor Mounts replaced aaaaaand...
I replaced my motor mounts(old ones were destroyed) and when I let off the brake and let the car coast the whole thing trembles. I have no idea what is causing this... (replaced top and trans mount) I THINK my trans mount is squeaking a little becuae if it idles in park for 2+ min the drivers side has a squeak..
Though the squeaking isnt a huge concern, i am worried about the trembling..
Attached is a pic of the old trans mount ( I shift much smoother now.. )
File Type: jpg 1621883_756454531031864_1310763660_n.jpg (82.7 KB, 84 views)
'96 SL1
INSTAGRAM: sw201444
sw201444 is offline   Reply With Quote
Old 03-12-2014, 02:12 PM   #2
lamping.ap
lamping.ap will become famous soon enoughlamping.ap will become famous soon enough
Default Re: Help! Motor Mounts replaced aaaaaand...
In what order did you do everything? Did you relieve the pre-load on the passenger side torque strut mount?
lamping.ap is offline   Reply With Quote
Old 03-12-2014, 03:14 PM   #3
dummo
dummo is a name known to alldummo is a name known to alldummo is a name known to alldummo is a name known to alldummo is a name known to alldummo is a name known to all
dummo's Avatar
from the way the old mount is mangled it looks to me like you have other problems.
Did it get mangled taking it out?
(I am not a mechanic - just a dude with a keyboard)
1997 SW2 used 12/29/2011 with 124,200 -27 mpg
2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
1994 SL1 new traded
1992 SL2 new traded for above
Old 03-12-2014, 03:53 PM   #4
NWSaturn247
NWSaturn247 will become famous soon enoughNWSaturn247 will become famous soon enough
NWSaturn247's Avatar
Matthew Broderick is a gifted, talented actor and the toast of Broadway!
1999 SL2 A4 -90k miles
Currently sipping Mobil Delvac 1300, Rislone & LiquiMoly mos2 + MotorKote Aug2020
TCW3 dosed fuel
1993 SL2 SOLD @189k
NWSaturn247 is offline   Reply With Quote
Old 03-12-2014, 04:23 PM   #5
sw201444
sw201444's Avatar
1996 SL1
Took trans mount out. Replaced. Took top mount off. Replaced. Then I went under the car. Loosened the mount on pass side on frame then retightened hoping it would cause less vibrations but it didn't.
'96 SL1
INSTAGRAM: sw201444
Old 03-12-2014, 04:25 PM   #6
sw201444
sw201444's Avatar
1996 SL1
Nope. It was like that! 225k miles of mount wear lol.
My mechanic(used to work at saturn) did it. I watched. But I did the bottom mount (loosened then retightened) myself
'96 SL1
INSTAGRAM: sw201444
Old 03-12-2014, 06:29 PM   #7
hholbein
Wow, when I replaced my tranny mount at 90K miles, the rubber was compressed by 4-6 mm and I thought that was bad. You're looked like jackals were chewing on it. Are you sure nothing else is amiss????
Old 03-12-2014, 06:56 PM   #8
lamping.ap
Maybe the trans mount isn't flush with the trans...Just an idea. Did you tighten the mount to the trans first? Then drop the trans the rest of the way and tighten the frame nut?
See the attachment for what mine looked like @ 137,500 mi. My new mount was OEM with an anchor stamp on it. Not sure what your replacement was.
Old 03-12-2014, 07:26 PM   #9
madpogue
1996 SW2
You need to loosen the _bracket_ that that dogbone strut attaches to. Two nuts on studs pointing downward. Then give the powertrain a little shake from above, to "re-seat" the bracket in its elongated holes, and re-tighten.
But ^^^^^ +1 dummo; what's up with the old mount? Looks like there was something out of place, rubbing against it. Maybe it's rubbing against the new mount now. Can you get a shot of the mount as it's installed now?
Old 03-13-2014, 01:16 AM   #10
The top engine mount & transmission mount are mainly load bearing with the top engine mount getting the big portion of vibration dampening. If the transmission mount was that bad/old....how old are the dog bones?
When I bought aftermarket dog bones & prothane inserts, people were bad mouthing the crap outta the dog bones but I've had them with the inserts at least 60k miles and other than a tad rusty they're good as new. Don't get the prothane inserts if you want a vibration free engine/idle though....they stiffen things up far too much & pass vibrations on rather then absorb them. Doesn't bother me other than really cold mornings when everything imaginable rattles but once it warms up the rattles settle down
Old 03-14-2014, 08:20 AM   #11
sw201444
sw201444's Avatar
1996 SL1
Not without a lift.. I have no jackstands at home.
I dis the passenger side dogbone. should i do the top/drivers DB too?
'96 SL1
INSTAGRAM: sw201444
Old 03-14-2014, 08:21 AM   #12
sw201444
sw201444's Avatar
1996 SL1
Yeah, see these rattles are only bad when car is still warming.. then the squeaking starts to kick in when the vibrating stops...
'96 SL1
INSTAGRAM: sw201444
Old 03-14-2014, 08:24 AM   #13
sw201444
sw201444's Avatar
1996 SL1
My mount was replaced at 225,000 that's why it's so mangled,everyone.
Also, I'm not sure, can I just go under the car(like the pass side dogbone) and loosen it, shake, then tighten?
'96 SL1
INSTAGRAM: sw201444
Old 03-14-2014, 08:40 AM   #14
Madness10
Madness10 will become famous soon enough
Madness10's Avatar
You don't have to go under the car. Take the resonator, the air box and the battery box out and you can get to the dog bone that way.
Madness10 is offline   Reply With Quote
Old 03-16-2014, 01:20 PM   #15
sw201444
sw201444's Avatar
1996 SL1
So I should replace that one?
'96 SL1
INSTAGRAM: sw201444
Old 03-16-2014, 05:02 PM   #16
Madness10
Madness10's Avatar
If the rest of the mounts were bad, then I would say yes. Again, only OEM, as the aftermarket ones have a softer rubber and wont last.
Old 03-18-2014, 08:26 PM   #17
sw201444
sw201444's Avatar
1996 SL1
UPDATE FOR ALL.
I went and replaced my top mount with my old one.. and what do you know, the newer top mount (with less miles) was causing all the vibrations! Rides like a new car with 225k miles on it... lol
'96 SL1
INSTAGRAM: sw201444
Motor Mounts adam22 S-Series Tech 5 06-24-2013 12:38 PM
Motor mounts on 97 sl2 jawynn S-Series Tech 7 05-02-2009 07:01 AM
I guess it was inevitable....front strut mounts & struts replaced Ritz Vue Tech 16 12-11-2008 05:17 PM
motor mounts jjsk8r85 S-Series General 3 02-24-2006 06:00 PM
WTT: SPS Motor Mounts for Stock Motor Mounts soccer69er Classifieds 1 10-28-2004 07:13 PM
