Old 03-06-2014, 10:24 AM   #1
sw201444
sw201444 is on a distinguished road
sw201444's Avatar
1996 SL1
Default Popping Sound!!
have a popping noise when turning.. sounds to be the drivers side that the sound is coming from. I checked my CV joints last weekend, no holes... THere was a post that It could be the security bolts on the Column. Anyone else have this problem? Anyone know what the problem is..?
Also... noise happens more when it's colder, when it's warmer it is rarer.
Add to sw201444's Reputation
Rate the quality of this post and help sw201444 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sw201444 is offline   Reply With Quote
Old 03-06-2014, 10:27 AM   #2
sw201444
sw201444's Avatar
1996 SL1
Default Re: Popping Sound!!
Also, 96 sl1.
Single cam and happy that way.
Old 03-06-2014, 10:40 AM   #3
caveeagle
caveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of light
caveeagle's Avatar
2005 VUE 2.2L
Just a single "pop" when you turn? Or is it repetetive? ...cycling with the wheel turning?
Lots of moving parts in the steering/suspension that can make noise. Thats why a little more detail would help.
Mark
'05 Vue, '02SL1, '01SC2a, '01SC2b, '99SL1 :::::> '04 SVT Cobra, '67 Mustang Vert.
Add to caveeagle's Reputation
Rate the quality of this post and help caveeagle reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
caveeagle is offline   Reply With Quote
Old 03-06-2014, 11:34 AM   #4
sw201444
sw201444's Avatar
1996 SL1
Sorry! First time posting. : It's when I'm turning the steering wheel left or right.. more common going left than right. not when going straight. SOMETIMES it happens when going over a speed bump..
EDIT: noise is also a "POP"
Old 03-06-2014, 11:51 AM   #5
SL19302
SL19302's Avatar
2000 SW2
2002 SL1
My buddy just had this issue it turned out to be a bad strut....
CHECK YOUR OIL!
Add to SL19302's Reputation
Rate the quality of this post and help SL19302 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-06-2014, 01:38 PM   #6
Jim97sl2
Jim97sl2 is on a distinguished road
Is the noise inside or can you hear it outside? If outside is it under the hood or from the wheel well?
Are all your bushings in good shape? Tie rod ends and ball joints sealed and not leaking or dried out?
Most likely would be strut mount bearing if it only happens when turning. Put it on jack stands and turn the wheel while listening for noise at the strut mounts. Also listen for noise at the spring seats as well. Less likely but possible, is the front sway bar bushings but that should also be present when braking or accelerating as the weight shifts fore and aft.
Jim
Add to Jim97sl2's Reputation
Rate the quality of this post and help Jim97sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jim97sl2 is offline   Reply With Quote
Old 03-10-2014, 05:05 PM   #7
DIYguy
DIYguy's Avatar
1997 SC2
Happy Re: Popping Sound!!
My "out of the box" suggestion would be to check the rubber bushings where the sway bar ends pass through the lower control arms, as Jim97sl2 suggested.
My car has had issues with them in the past and in fact they are getting a bit ragged-looking at the present time (soon to be replaced).
If bad enough they will definitely cause popping noises even when transitioning from reverse to forward in a parking lot at walking speeds.
They did that on my car anyway.
Also check to see if your sway bar front bushings (where it passes against the front of the sub frame) are worn.
Look for any evidence at all that the sway bar is contacting the sides of the sub frame where it passes really close at the corners.
Look for rub marks on either one.
If you find them, start looking for culprits.
Suggestions from others such as struts, strut mounts, and so forth are also good things to check for of course.
There is a remote possibility that the lower end shaft bearing on the steering column has loosened up.
That also happened on my car.
It is pathetic, wimpy thing that only belongs on Tonka toys.
Mostly you'll hear that as a clunk or rattle when turning a corner if you hit a bump or rut in the road.
I posted a permanent fix for it a while back (with photos ).
The fix has held up for years now.
DIYguy
Quando Omni Flunkus Moritati
Add to DIYguy's Reputation
Rate the quality of this post and help DIYguy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-11-2014, 12:21 AM   #8
Chub
Chub will become famous soon enough
Chub's Avatar
This may be a total shot in the dark but were the struts / springs on the front changed recently?
If so, the rubber "seat" between the strut mount and the the top of the strut may be on improperly which can cause rubbing and this can make a popping noise.
1995 SC2: Back on the road again after my second engine rebuild in two years.
Add to Chub's Reputation
Rate the quality of this post and help Chub reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Chub is offline   Reply With Quote
Old 03-12-2014, 01:20 PM   #9
sw201444
sw201444's Avatar
1996 SL1
Jim
I would have to look when it's lifted again. But I notice it when going over large bumps and/or potholes, also very very rarely when accelerating.
'96 SL1
INSTAGRAM: sw201444
Old 03-12-2014, 01:21 PM   #10
sw201444
sw201444's Avatar
1996 SL1
If you can post a pic reply with the part I can tell you if it's rotted or not.. I did notice some dry rot.
'96 SL1
INSTAGRAM: sw201444
Old 03-12-2014, 01:24 PM   #11
sw201444
sw201444's Avatar
1996 SL1
Nope, but I will be getting 2" lowering springs (main reason I wanted to solve this)
'96 SL1
INSTAGRAM: sw201444
Old 03-13-2014, 10:55 AM   #12
Jim97sl2
If you can't find any noise in the items listed above, you may also want to check for exhaust clearance and the condition of the isolators as well as for any bent hangers. Exhaust to chassis clearance issues are usually accompanied by a thump and depending on location, you can sometimes feel it in the floor board.
Jim
Old 03-14-2014, 08:23 AM   #13
sw201444
sw201444's Avatar
1996 SL1
Jim
My exhaust mount broke.. waiting to get it replaced..(held up with metal wire, like a coat hanger) but I'm almost positive that's not what this issue is..
'96 SL1
INSTAGRAM: sw201444
Strange rattling/popping sound Kzaharris S-Series General 3 02-13-2013 11:05 PM
popping sound from exaust Scott Peterson S-Series Tech 10 05-16-2008 12:19 AM
Popping Sound When Turning oceanjoe89 S-Series Tech 4 06-26-2006 12:22 PM
Sputtering/popping sound when idling... blarghface S-Series Tech 1 06-06-2006 06:46 PM
Popping sound Scout238 S-Series General 1 05-13-2005 02:55 PM
