Old 06-11-2005, 03:25 PM   #1
Bill Z
Bill Z is on a distinguished road
Default Radiator Fan doesn't blow without the AC on
My 99 L Saturn with DOHC radiator fan turns on with the AC but without tie AC on the car over heats at stop lights.
I have a scanning tool and the temp sensor seems to be telling the ECM what the temp is. I can see it going from 80 to 193 degrees over about 10 minutes of idling in the garage. The dash temp gague only goes to 1/4 and not amy more.
I disconnected the 2 wire sending unit and the temp on the ECM went to somtening like -40 degrees. I reconnected and it displayed a temp. I disconnected the one wire sending unit and the temp gauge on the dash went to zero.
Since the AC makes the fan work, the fan doesn't have a problem. Tje 30 amp fise is good. The AC relay is working. The fan relay is working.
So, what makes the fan turn on? Where do I check?
Bill Z is offline   Reply With Quote
Old 06-11-2005, 04:08 PM   #2
buyobuyo
buyobuyo is on a distinguished road
Default Re: Radiator Fan doesn't blow without the AC on
Sounds like it is working like it should too me. Assuming that the L-series fan operate in the same fashion as the S-series fan.
buyobuyo is offline   Reply With Quote
Old 06-11-2005, 04:48 PM   #3
SATURNER
SATURNER is on a distinguished road
SATURNER's Avatar
What is the exact model designation?
Hang up and Drive
SATURNER is offline   Reply With Quote
Old 06-11-2005, 05:05 PM   #4
Bill Z
Shouldn't the fan start up when the engine gets to around 180- or 190 degrees?
This fan doesn't start at all with the AC off. That to me is wrong.
What temp should the fan turn on with the AC off?
Old 06-11-2005, 05:31 PM   #5
96GSL1
96GSL1 is on a distinguished road
96GSL1's Avatar
1996 SL1
Fan probably won't run until around 220. Most thermostats' won't even open until 180+.
96 SL1 202k
98 Windstar 123k
96GSL1 is offline   Reply With Quote
Old 06-11-2005, 05:37 PM   #6
SATURNER
SATURNER's Avatar
You may have a faulty temperature sensor (two wire). You might try hooking up your scantool when the car is COLD and comparing the reading to the ambient temperature.
If by overheating you mean coolant is boiling, you might check your antifreeze concentration, and pressure cap.
Hang up and Drive
Old 06-11-2005, 09:26 PM   #7
You have a few problems.
#1
You are in the L-series forum with an S-series from what you say the year is.
#2
If you have a two wire AND a one wire temp sensor then you don't have a 1999 model year car.
So you likely have a 91 to 95 S-series car.
Replace the PCM temp sensor (the two wire one) and the connector for it if there is any corrosion in the connector terminals. Reading the temp number from a bad temp sensor will only get you the bad numbers. Compare the PCM temp sensor readings (via scan tool)to the coolant temp in the surge tank (via a thermometer). The radings should be within 5 degrees F of each other.
Radiator Fan caepperson3 S-Series Tech 6 07-31-2009 09:40 PM
radiator fan Mil Astra Tech 20 02-06-2009 08:18 PM
Radiator fan? whistler19 S-Series Mods 17 06-04-2007 01:36 PM
Radiator Fan ... clearnet_tw S-Series General 1 05-05-2006 02:44 PM
radiator fan? PunkerTFC S-Series General 7 01-16-2004 06:35 PM
