Old 12-29-2013, 01:42 AM   #1
blackbeard
blackbeard is on a distinguished road
blackbeard's Avatar
1993 SC1
Default The Last Minute!!!
Ok, only a couple more days till the smog test and it is time to refill the gas. Should I use Chevron? High or low octane?
Does it matter?
Should I change the oil filter?
Seafoam it?
Clean the air filter?
Change the oil?
Put new spark plugs in it?
Change the o2 sensor?
blackbeard is offline   Reply With Quote
Old 12-29-2013, 10:06 AM   #2
caveeagle
caveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of light
caveeagle's Avatar
Default Re: The Last Minute!!!
Do you have some reason to suspect it won't pass the smog test as-is??
That seems like a lot of work if your cars currently running ok.
Mark
'05 Vue, '02SL1, '01SC2a, '01SC2b, '99SL1 :::::> '04 SVT Cobra, '67 Mustang Vert.
caveeagle is offline   Reply With Quote
Old 12-29-2013, 01:00 PM   #3
If the air filter and plugs are known to be cruddy, then replace them; forget all the rest (unless there is some other know problem, as said before). Go to a test station that gives a "free retest", they don't cost any more than others.
Old 12-29-2013, 04:27 PM   #4
el diablo viejo
el diablo viejo will become famous soon enough
el diablo viejo's Avatar
1994 SW1
2000 SW2
^^^^+1 Any check engine lights on ?
97 sl2 a/t 104 K
1989 GMC 3500 454 129 K, 1969 442 455 rat rod
el diablo viejo is offline   Reply With Quote
Old 12-29-2013, 05:15 PM   #5
ehunter
ehunter has a spectacular aura aboutehunter has a spectacular aura about
Location: Pacifica by San Francisco Ė 5sp Ė Engine rebuild with the help of people here at 177K due to 500mi/qt oil consumption. After 2yrs I am back to 40mpg+ after discovering the refirb head I used was bad. Car runs better than a top. Now at 214k.
1996 SL2
Get yourself a USB laptop scanner for $20 to know if improvements can be made to your ignition burn characteristics.
I think the air filter, to a certain point, may be a waste of your money unless it is overly filthy. If it is just lightly or moderately dirty the computer compensates for any reduced air flow. In history it was more important to keep a clean air filter, but it is not as important today.
To be realistic though, make sure your plugs are cleaned, gapped, no corrosion on the wire set, and this will be the best you can do in a short period of time. Longer term get yourself a USB scanner. That will tell you where improvements can be made. Ask here if you are not sure which scanner package people prefer.
ehunter is offline   Reply With Quote
Old 12-30-2013, 01:11 AM   #6
blackbeard
blackbeard's Avatar
1993 SC1
The problem is, last time I had it smogged, it barely passed. I really want to make sure it passes this time, otherwise the government will have succeeded at removing another good ol' car from the road.
Old 12-30-2013, 01:51 AM   #7
code1bob
code1bob is a jewel in the roughcode1bob is a jewel in the roughcode1bob is a jewel in the rough
code1bob's Avatar
1997 SL1
Make sure it is warmed up prior to the test.
I would be sure to have a clean air filter, also fresh oil. I also have some high octane fuel in the tank.
It is important to make sure the tech lets the vehicle get warmed up prior to starting the test. My tech seems to run it at about 2,000 rpm for a couple of minutes before he starts the test.
1997 SL1
5 speed manual
348,001 mi.+
code1bob is offline   Reply With Quote
smog check tips
Please Clarify 10 Minute \ 30 Minute Reset Settings pjkovie L-Series Tech 4 04-20-2012 11:53 PM
Revolutions Per Minute Red Sc2 S-Series Tech 14 01-16-2007 10:11 AM
Last minute Purchase! ClapDaddy General Saturn Discussion 18 01-08-2006 03:35 PM
Hesitation at 60- 70 MPH once every minute starbuckcylon L-Series General 1 12-29-2005 04:32 PM
this gets better by the minute... joeybagodonuts General Saturn Discussion 3 04-02-2001 09:38 PM
