Old 12-30-2015, 10:17 AM   #1
Cronusheart
Cronusheart is on a distinguished road
Default Hanging RPM, p1174 Code.
Hello,
About a month ago my car threw a p1174 code. Since then I've noticed that the rpm hangs at 1400 when coasting in neutral, and will drop to idle when the vehicle stops. The problem appears to be intermittent, and I can't figure out under what conditions it occurs. Any ideas on how to correct this issue?
Thanks, SaturnFans!
2006 ion3, 2.4l
Cronusheart is offline   Reply With Quote
Old 12-30-2015, 02:02 PM   #2
toggenburg
toggenburg's Avatar
Default Re: Hanging RPM, p1174 Code.
Hi, Welcome to Saturnfans!
If you are referring to your ION, to get the best advice you might try reposting in the ION section of Saturnfans.
However; IF you have an S-series car, then you don't have the right code.
Help! P1174 AlyDot06 Ion Tech 1 10-03-2011 03:13 PM
P1174 code help please!! chief58 Canadian Saturn Owners 2 03-20-2011 04:42 PM
DTC code P1174 Ctaylor Ion Tech 29 09-12-2010 05:49 PM
Speedometer hanging up? Oceanair S-Series Tech 3 11-11-2006 10:14 PM
Hose hanging down 02VUE93SL Vue Tech 5 06-04-2005 08:46 PM
